Old 03-19-2007, 06:44 AM
Big"E" is on a distinguished road
Cutting S.S. 304
What is a "good" starting point cutting a pocket on 304 stainless? Machine is a HAAS VFOE (20HP) endmill is a 5/16 Diameter 4 Flute TILACLN designed for S.S.
The doc (depth of cut) is 0.100" with a 50% step over
The setup is rigid, with plenty of coolant.
The cam software (M.C.) shows Speed 1836 and a Feed of 6.4, that appears to be a bit aggressive for 304
Any suggestions on where to start?
After the slot I need to cutthe outside profile, so I need to get a good starting point.
Old 03-19-2007, 01:04 PM
cdlenterprises is on a distinguished road
Sounds a little slow. I usually figure about 250-300 spm for milling stainless. I might bump the feed up a little, too. You don't want to go too slow in 304 or you'll dull the cutter. Try 2500-2800 rpm @ 15 ipm. see what it sounds like and go from there
I don't know much about anything but I know a little about everything....
Old 03-19-2007, 01:06 PM
jackson's Avatar
jackson is on a distinguished road
i would start at 75sfm 1000rpms 4ipm and a good carbide cutter and run it dry
individual who perceives a solution and is willing to take command. Very often, that individual is crazy.
Old 03-19-2007, 01:08 PM
jackson's Avatar
and reduce your doc by half
Old 03-19-2007, 01:39 PM
bbern is on a distinguished road
i'd go 3058 RPM,11 IPM, 7 IPM on the first full diameter entry cut. also try to interpolate the corners,instead of plunging full dia. into them. on the profile, depending on the radial and axial DOC, i'd go up to 300 SFM or so (3667 RPM) and 15-18 IPM.
Bill
oxy gasoline cutting torch - oPetrol cutting torch denniswang Product Announcements & Manufacturer News 6 02-20-2010 04:23 PM
cutting oil for SS sanjiv Mechanical Calculations/Engineering Design 2 10-28-2006 01:36 AM
I need help about cutting heads which apply to apparel pattern cutting machine sheepgrass Mechanical Calculations/Engineering Design 0 05-12-2006 01:09 PM
Cutting SS or Ti Possible? bprzybyl Mechanical Calculations/Engineering Design 11 04-11-2006 05:01 PM
