Old 03-10-2007, 08:24 PM
lostbaka is on a distinguished road
Drill Jig For Electrical Receptacles
Not sure if this is the right place for this but here goes:
The company I work for builds electrical distribution boxes. Of course, we use alot of flanged electrical receptacles. They usually consist of a square pattern for the mounting holes and one larger hole in the center for the actual receptacle inlet\outlet.
Normally a box would only have a few receptacles so drilling each hole (drilling or punching with a Greenlee driver for the center holes) isn't that time consuming. But I was watching the guys build a box with 30 receptacles.
What I was wondering is there any commerically available multi-drill jig or a way to build one to take this operation from 5 steps to just 2?
Frank
EE Undergrad
Engineering Intern
Spade Drill Does Work in Aluminum; Big Hole Boring on Drill Press. Geof General Metalwork Discussion 47 02-01-2008 01:32 PM
I need help choosing a mini electrical drill. Calvi General Metal Working Machines 6 02-23-2007 05:05 AM
Electrical Interference Scratch CNC Plasma and Waterjet Machines 0 01-13-2007 10:49 AM
Can I drill AISI 1020 plate steel with a drill bit? Apples General Metalwork Discussion 2 02-01-2006 11:15 AM
Where are the electrical symbols? balsaman Autodesk Software (Autocad, Inventor etc) 6 01-11-2004 09:32 PM
