Old 03-09-2007, 03:56 PM
MBG MBG is offline
MBG is on a distinguished road
Mild Steel
When people say "mild steel" are they refering to mild steel or is there a number to it? I looked up online for mild steel and can't find it.
Is it under cold rolled or anything like that?
Old 03-09-2007, 04:20 PM
Mild steel is a general term. Cold rolled steel C1018 is mild steel, hot rolled steel is mild steel, leaded steel C10L14 is mild steel. Here is a definition of mild steel.
Carbon steel is sometimes referred to as 'mild steel' or 'plain carbon steel'. The American Iron and Steel Institute defines a carbon steel as having no more than 2 % carbon and no other appreciable alloying element.
Steel with between .3% and .8% carbon is Medium carbon steel and above .8% it is High carbon.
If the steel has other alloying elements such as manganese or cobalt, etc., it is called alloy steel and if it has chromium it is called stainless steel.
RFQ: Milling needed in mild steel. SCCoupe Employment Opportunity 2 12-10-2006 08:06 PM
RFQ - on 1/2" mild steel plate BullCreek Employment Opportunity 5 07-10-2006 06:31 PM
Plasma cutter for 3mm mild steel DEEDEE CNC Plasma and Waterjet Machines 5 01-19-2006 05:25 PM
Machining Mild Steel georgebarr General Metal Working Machines 5 06-29-2005 06:54 PM
A Mill for milling HSLA and Mild Steel deep_drill General Metal Working Machines 3 06-06-2005 11:29 PM
