Old 03-07-2007, 01:59 PM
groovemixer's Avatar
groovemixer is on a distinguished road
Holtests, Hole micrometers???
I'm looking at getting holtests for holes of .240" up to 1" ID, measure to +/- 0.0002". Was wondering if Brown and Sharpe are a good brand, I usually buy Mitutoyo. Also are the small hole guages good enough? The ones that are set to the hole size then measured with a micrometer.
Old 03-07-2007, 02:26 PM
jackson's Avatar
jackson is on a distinguished road
B&S is good but i stay with mit. and starret just a prefrenss i say stay with what your use to and trust and yes the gauges are good enough.
individual who perceives a solution and is willing to take command. Very often, that individual is crazy.
Old 03-07-2007, 03:10 PM
The telescoping gauges can be ok in experienced hands. The cheap telescoping gauges being sold lately are not dependable, they bind up and stick. Measuring +/-.0002" reliably is difficult enough without trying to do it with junk.
DZASTR
Old 03-09-2007, 12:14 PM
BobWarfield's Avatar
BobWarfield is on a distinguished road
How about a bore gage? Mitutoyos were on sale recently at Enco, I think.
Best,
BW
Old 03-09-2007, 02:10 PM
ajl6549 is on a distinguished road
Best,
BW
I agree if your not experienced with telescoping gages try dial bore gages.
A.J.L.
Old 03-09-2007, 02:54 PM
jackson's Avatar
Your best bet is to use tri mics if you have to hold a tite toleranc
Old 03-09-2007, 05:22 PM
That seems not to be totally the conventional wisdom. For example, the trimics can't measure certain kinds of irregularities with 3 points that you can find with 2. I started out on the trail of trimics and had a bunch of people over on the PM boards push back in favor of bore gages. It's worth searching over there to see if you agree with their thinking.
Best,
BW
Old 03-09-2007, 09:47 PM
Zumba is on a distinguished road
I've got the Mitutoyo bore gages from 0.7 to 6.0 (three sets).
The smaller ones are freaking expensive. Much better than telescoping gages though. You won't be able to get .0002" accuracy with those.
Old 03-10-2007, 05:43 AM
jackson's Avatar
Best,
BW
Well i have used both and both have there place i have found that the tri takes a more true reading "yes i know it takes an avrege by three or what ever" but of all the places i have done work for i have never had a part rejected when using tri mic, bore gages "i still use them" but i have been bit more by them than any tri mic!!! just my opinion and what i know
Old 03-11-2007, 11:04 PM
Newby2 is on a distinguished road
For a .0002" tolerance a tri mic or bore gage is the only way to go. telescopes are outdated and inaccurate. They may get you to within .003" if you are experenced. With a tri mic, you should have a certified master that came with the mic. If you don't have the master, then I would doubt the accuracy you are trying to hold.
Steve
who makes best coolant proof micrometers?? blazer928 General Metal Working Machines 7 03-10-2007 12:58 AM
Drill hole avengine CNCzone Club House 0 04-29-2006 07:33 PM
How do you drill a hole? CuttersCov General Metalwork Discussion 13 02-28-2006 07:33 AM
finishing a hole fastolds GibbsCAM 3 08-25-2005 07:06 PM
Milling a hole igorko General CAM Discussion 25 01-30-2004 05:55 AM
