Results 1 to 10 of 10
Thread: What tools are required in your shop?
    Apr 2004
    Ok will im looking to get a job here sooner or later. Most if not all require you to have your own tools. Can you guys help me out and post what tools are required in your shop?
    Registered Mitsui Seiki's Avatar
    Feb 2007
    Yeah,I'm moving to Long Beach,CA from Sweden in July.
    I'd like to know that too.
    Jan 2007
    I don't recall what is actually required, but these are the tools I use frequently:
    calculator
    dial (or digital) calipers, 8 in. (good) 12 in. (better)
    depth mikes, 0 - 6 in. (good) 0 - 12 in. (better)
    O.D. mikes, 1 - 4 in.
    telescoping gages , .25 - 6 in.
    I.D. mikes, 2 - 12 in.
    dial indicator
    offset indicator holder
    magnetic base
    wiggler, edge finder
    hex wrenches, SAE & metric
    adjustable wrenches & standard mechanics wrenches, sockets, ratchet
    The larger O.D. micrometers and precision bore gages are available at work.
    What tools you will actually NEED really depends on the type of machining you do.
    Best of luck with the job search
    May 2005
    To Add to the list:
    Scribers
    Double square or
    Combination square or both
    Soft hammers (brass, & plastic)
    Flashlight < can be very important.
    Hacksaw
    Various deburring tools "Shavis"
    Machinerys Handbook
    Actually at the top of the list should be a Lockable TOOLBOX.
    In any event as Eurisko points out it depends on what you will be doing. Even more so it depends on the facility you are in. You may very well be required, in some shops, to use company supplied and calibrated measuring tools for example.
    Note that you can often supply yourself with "tools" out of the scrap bin also. Things like scribes, punches and drifts are just another name for scrap in some eyes.
    The important thing to do is to make sure you clear up requirements at the point of job acceptance. You might want to bring it up in the interview, but I wouldn't get to carried away at that point. As a side note I work in an allied trade, and brought the question up and they gave me the wrong answer. It is a good idea to get the right answer from somebody that supervises on the floor.
    Dave
    Apr 2004
    Thanks for the help kind of gives me something to look at. As of now im still in school but every tool i buy is a tool i can use at school to make my life easier. Problem runs into the cost.
    Couple more questions, As you said a toolbox. What is your(anyone?) view on wood ver metal? For a on the job use toolbox.
    Another question. What about tool brands. Myself i love to buy name brand tools but If a company gave me a list of tools as above. That could run into the thoudsands. If you showed up with a chinese combination square are you going to get laughed out of the building?
    Registered WayneHill's Avatar
    Mar 2004
    Michigan
    Common sense is the only requirement at our place. No toolboxes. All tools and gages required are supplied.
    Anyone can buy tools.
    Tools do not make a machinist. Knowledge makes a machinist.
    Wayne Hill
    Jan 2007
    united states
    Yes Knowledge makes a machinist but can you set tools with your bare hands? Come on man!
    CNC Set Up Machinist -Twin Turret Turning on Mori-Seiki and Mazak
    Mar 2005
    Toronto, Canada
    Quote Originally Posted by WayneHill View Post
    Experience. Knowledge. And several large tools box stuffed the brim with Starrett, B&S, Mitutoyo, Etalon, Moore and Wright, etc etc.
    wouldn't be any fun if you didn't collect and make all the stuff
    Nov 2005
    Yes. Everything mentioned previously, not limited to but including, your own CMM and a ton of new Carbide endmills Just kidding.
    Just be careful with the hammers as it really scares employers when they see a new hire with a 2 pound ball-peen hammer in his hands anywhere around their expensive machinery! I cant' count the times I've seen this.
    Actually, my first toolbox was a plastic fishing tackle box with a pad lock on it. Cheap and it worked fine until I could afford a Kennedy.
    Mar 2004
    Michigan
    Quote Originally Posted by Mcgyver View Post
    My Kennedy toolbox stuffed with Starrett, B&S, Mitiutyo, etc.. tooling is sitting in the basement workshop. It is the first place I ever worked where a toolbox was not required. I really do not miss not having a toolbox at work. The factory is ISO certified. It makes gage calibration certs much easier if the tooling is company owned.
    Wayne Hill
    1. Bring your own tools or does your company supply tools?
      By ZipSnipe in forum CNCzone Club House
      Last Post: 02-04-2011, 08:06 PM
    2. Replies: 34
      Last Post: 09-11-2008, 08:13 AM
    3. UK CNC Guru required
      By Drakkn in forum Mentors & Apprentice Locator
      Last Post: 12-19-2007, 11:53 AM
    4. Help required...Surfaces
      By zedzero in forum Mastercam
      Last Post: 01-13-2007, 04:18 PM
    5. Help Required on CNC Hobbing
      By ablogsol in forum General Metalwork Discussion
      Last Post: 06-12-2006, 03:32 AM
