I have a cheap HF Mill / Lathe combo. I am trying to figure something out (I am not experienced in either). After purchasing I figured out that the mill only came with a 1/2 drill chuck. I read the documentation and found it used morse taper 2 collets. I purchased some. I then proceeded to buy end mills. Now that I have everything "I thought" I needed I found out that when the mill is completely extended it is 4.5 inches from the bed. How do I get the bit closer to the table. If anyone cares I have provided a link to the manufacturers pdf. http://skywasyellow.com/5980.pdf Thank you in advance for any help! -Ronnie |
| Hi. I just replaced the top two bearings under the step pulley in the mill head because I didnt know that the work must be fairly close to the mill in the most up position you can get it, this is achived by making a tilting table attaching it to the bed with a vise on same and you can get real close to the mill cutter tool this way. If you havent joined the 3_in_1_Lathe_mill_drill yahoo group you should their is a lot of info on this machine check out the photos sections under Harbor Freight 5980 for pics of the mill holder and tilting table and other modifacations. good luck Cap. dont give up the ship... |
| Well GHawkins as you can tell from my number of posts I am new my self to this group but I do enjoy helping and talking about metal working I have a garage full of small equiptment. What are your metal interests?? Cap.
__________________ Don't Give Up The Ship !!! |
| General Mill purchasing question. | l u k e | General Metalwork Discussion | 5 | 03-01-2007 11:05 AM |
| GN6 (General Numeric) Helical milling | pauldkeeton | Fanuc | 5 | 02-23-2007 03:42 PM |
| general newbie question | charper | Vacuum forming, Thermoforming Etc | 15 | 11-29-2006 09:51 AM |
| General Machining Question: | rhino | Mechanical Calculations/Engineering Design | 6 | 07-22-2006 09:18 PM |
| General Question | CNCRob | Machine Problems, Solutions , Wireless DNC, serial port | 5 | 05-21-2005 11:38 AM |
