| Today, I've machined maraging steel . This material is difficult to cut because the chip form is problematic and the strength is high, but it's easier than Superalloy (Inconel, Monell,...) My case was: Doing thread M0.8x1mm (for watch industry). |
| Hey guys, I need your help in cutting maraging steel. I have a huge block of maraging steel which has been annealed to 28 - 30HRC. I need to slit this block into smaller pieces and later machine the smaller pieces. The size of the block is about 500mm X 350mm X 1500mm long. The cut pieces will be 500mm X 350mm X 200mm in size. Here come the doubts 1. Can this be done on a slitting machine? 2. What kind of siltting saw will I need to use to cut this material? 3. Can I use a band saw cutting machine? If yes, what is the grade of bandsaw that I will need to use? Would appreciate all your inputs regarding this. Thank in advance. |
| Steel bench for X3 | keen | Syil Products | 31 | 04-19-2007 01:47 PM |
| How many hp i need to cut steel? | tivoidethuong | DIY-CNC Router Table Machines | 32 | 05-04-2006 09:39 PM |
| Steel Rod | georgebarr | DIY-CNC Router Table Machines | 5 | 05-21-2005 10:32 AM |
| why not steel? | NeoMoses | DIY-CNC Router Table Machines | 15 | 09-11-2004 09:14 PM |
| How do I cut steel? | samualt | DIY-CNC Router Table Machines | 8 | 06-30-2004 10:49 PM |
