There is a geometry page that is numbered from 1-64
Which Height Offset are you using G43 or G44?
Z0 is usually set from the highest point on a part. To set this up using G43 you would use the Handle to bring down the Z Axis to the Top of your Part and Input your Machine Position Numbers on the Geometry Page. This page is found by hitting the Offset Settings button.
Touch all your tools in the same manor. Save Offsets 31-64 for Radial Cutter Compensation G41/G42
T1 Offset 1 =H1
T2 Offest 2 =H2
T3 Offset 3 =H3
Program example:
O1124
G0 G17 G40 G49 G80 G90
G54
T1
M6
M1
N100(SHELL-MILL 3.0)
S1018 M3
G0 G90 X-7.875 Y-1.0
G43 Z1.0 H1
Z.1 M8
N101 G1 Z0 F50.0
N102 X1.875 F31.0
N103 G2 X2.375 Y-1.5 R0.5
N104 X1.875 Y-2. R0.5
N105 G1 X-7.875
N106 G0 G90 Z1.0
G0 G90 G99 M9
G0 G40 G98 M5
G28 G91 Z0 M19
G49 G90
M30
LinkBack URL
About LinkBacks
