Old 02-21-2007, 07:37 AM
Gold Member
InspirationTool is on a distinguished road
Flood cooling and a deep pocket vs through-cut...
I'm cutting through an aluminum block 1.5" deep with a 3/8" cutter.
I'm using flood cooling. The chips pack up underneath the through cut and then the chips start coming out of the top. The coolant still flows out the bottom.
I'm wondering if I would be better off with a sacrificial plate underneath, turning it into a deep pocket. That way the cutter is completely submerged, and the chips always flow up and out, rather than the flow pushing the chips down and the cutter pulling them up. I figure the coolant will be helping the flow then.
Any ideas?
Thanks!
-Jeff
Old 02-21-2007, 08:45 AM
jetski is on a distinguished road
Jack the plate higher and use another coolant line under the plate. Double cutting the chips just wears the cutter out faster. Just a thought without seeing the part. I always use tall rails to help get the chips out on a through cut.
Had it with flood cooling jdholbrook Benchtop Machines 38 10-24-2008 06:47 AM
MicroDrop or Flood Cooling wildcat General Metal Working Machines 24 06-08-2007 10:13 AM
milling deep pocket barnesy General Metalwork Discussion 8 09-16-2006 05:00 AM
Flood Cooling - build or buy???? bill south Mechanical Calculations/Engineering Design 8 03-13-2006 06:04 PM
Flood cooling rocks!!!! JFettig Benchtop Machines 16 09-17-2004 05:01 PM
