Old 02-15-2007, 01:52 AM
rainman is on a distinguished road
Invert 12V to -12V
Hi all, I intend to invert a 12VDC battery pack supply to -12VDC, which then will feed into a analog motion controller, which takes in +-12V.
Please advice how should I go abt it? Any Line driver or op amp that can do the job?
PS : The +-12V supply had to be minimum 0.3A.
Thanks!
Old 02-15-2007, 05:58 AM
epineh is on a distinguished road
I have seen a circuit like this in a 555 timer project book, I don't think the output current was all that high, I will see if I can dig it up. Can you make yourself a simple board and circuit ?
Either that or just get another battery and connect them in series, and take the mid point as your 0volts, instant +- 12 Volts.
Russell.
Old 02-15-2007, 08:41 AM
pastera is on a distinguished road
Digikey 445-2489-ND $15.08
12V isolated DC/DC converter
Most charge pump type units are not able to output 300mA.
Aaron
Old 02-15-2007, 09:43 AM
Gold Member
CJL5585 is on a distinguished road
Thanks!
I am assuming that you have an existing +12 Volt supply and you need a -12 volt supply. If you need to create both supplies, one can use two 12 volt batteries.
To convert a 12 Volt battery pack to a -12 Volt DC system, ALL YOU HAVE TO DO IS TO CONNECT THE + WIRE FROM THE ADDED BATTERY TO THE - (minus) SIDE OF THE existing supply per below.
(+) Terminal........................................ +12 Volts
. EXISTING +12 Volt Supply
(-) Terminal (ground side of +12 Volt supply)
| Connection ................................Supply Ground or 0 Volts DC
(+) Terminal of 12 Volt battery
. Battery
(-) Terminal of Battery is -12VDC............... -12 Volts
The Voltage across the existing supply and battery will be 24 Volts DC. The connection point will be the 0 Volt or supply ground.
Hope this helps.
Jerry
Invert code JW Peters G-Code Programing 3 03-09-2006 09:06 AM
Table setup - Axis invert horse Kellyware CAM 0 02-28-2006 08:45 AM
How to invert slave motor direction? toolbox911 Stepper Motors and Drives 3 02-14-2006 09:16 AM
