| http://www.lasercenteredgefinder.com/ for the money it looks pretty cool this is what i use ,a bit more in price but well worth the money http://www.wenzel-wkp.nl/Nieuws/3D_t...ster_ip67.html |
| Why would wood make a difference with a laser dot?Without making this too hard, do you have any concrete conclusions metal would present kind of a problem? The one I own seems to work ok on metal (no wood -yet). I just "split" the red dot when aligning scribe marks. (saves using the 'ol centerpunch approach or a wiggler) Pres |
You are not going to get +-.002 out of it but +- .005 is more along the range. For a lot of work that is more than adequate. What I find it most useful for is very quick positioning holes that have been previously laid out. An example would be a series of transfer punch marks indicating where holes need to be placed. Mating to an existing pipe flange is a good example. The old way; if there were an even number of holes, I could measure the bolt circle and calculate the x and y positions and take into account any rotation of the pattern. With the laser pointer I hold the piece in place, mark the hole locations, clamp down the piece, position it under the laser and drill, reposition and drill. I do not need to measure or calculate to get the holes right where I want them. This little device has saved me a lot of time. |
Thats pretty much what I had figured. I don't really need an edge finder but for the price I may pick one up. |
| I have one, and don't find it any good for picking up edges. Seems to pick up pin pricks quite well though. I got an lighted electronic edge finder... I am getting good use out of that one. I don't have to worry about it rubbing while I fiddle with the computer to input the offset. -Jeff |
#10
| I also think there are far to many variables in a non-contact referencing device to trust it much below 1-2 beam widths and even that could be exponential the further distance it is pointing at IF the beam is not rotated on the axis to verify a true centerline. Their video shown in operation and only one instance was it rotated in the spindle. The runout of the beam was far too obvious. I don't think it is a fair comparison in competition to a standard edge finder or indicator, but I can see where it would handy in a few rough and rapid setups. Then take a true reference cut to set 0,0. If the head is out of tram or the work holder doesn't hold it properly on center or straight, I liken it's trustworthyness on par with a square and a plumb bob! DC
__________________ Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade. |
#11
| I will have my guys stick with the regular edge finders, the laser to me is just like digital calipers just dont trust them
__________________ individual who perceives a solution and is willing to take command. Very often, that individual is crazy. |
#12
| (see link below) This is no doubt my favorite edge finder. It is expensive, but you get what you pay for. I can pick up x, y, AND z off a corner in about 30 seconds total, and NOT have to offset for edge finder diameter. I experience .0001" - .0003" repeatability in x and y, and about 0.0005" in z. You will also need a ring gage to calibrate it in your particular machine. The only more accurate method that I know is to use the indicator and gage ring method, but that is a LOT slower. http://www1.mscdirect.com/CGI/NNSRIT...MT4NO=18267548 |
| Question About Edge Finder | FLUTE HEAD | Machine Problems, Solutions , Wireless DNC, serial port | 16 | 09-29-2008 01:21 AM |
| Laser edge finder | dave6 | Calibration & Measurement | 9 | 12-10-2006 09:06 AM |
| anyone know where to get this optical edge finder? | mbwittig | General Metal Working Machines | 6 | 10-24-2006 01:33 PM |
| Anyone have a edge finder G-code routine? | InspirationTool | General CNC (Mill and Lathe) Control Software (NC) | 5 | 10-02-2006 07:48 PM |
| Manually starting spindle with edge finder | diemaker76 | Fadal | 21 | 04-13-2006 06:13 PM |
