Old 02-12-2007, 01:51 PM
M-man is on a distinguished road
Insert for 62 Hrc
Is there any insert that will manage to bore up a 24mm hole to 26mm and relocate it 1mm, in a hardened steel that are close to 62 Hrc ?? Geometry of insert should be dcmt 11T3xx Thanks
Old 02-12-2007, 05:15 PM
jackson's Avatar
jackson is on a distinguished road
i dont fully understand the relocate part, and what kind of tool are you using
individual who perceives a solution and is willing to take command. Very often, that individual is crazy.
Old 02-12-2007, 08:26 PM
Tim S is on a distinguished road
Check with your supplier for a CBN insert in the DCMT style. CBN is expensive, but well worth it. If it is 1 piece, you might get away with carbide, running dry and slow. LIGHT cuts!!!
HTH
Old 02-13-2007, 07:51 AM
cdlenterprises is on a distinguished road
Sounds like you're trying to repair a part. Can you EDM? If it's a repair it may be less of a headache.... You could also look into ceramic in addition to CBN. They may be a little cheaper. There was a post recently about silicon nitride inserts in this forum. I believe they were from Ingersoll cutting tools. You may want to look into them as an alternative.
I don't know much about anything but I know a little about everything....
Old 02-13-2007, 02:00 PM
What do you mean with EDM?
Old 02-13-2007, 03:09 PM
pastera is on a distinguished road
Electro Discharge Machining
You could easily offset the hole with an EDM where the interupted cut would be a little hard on an insert
aaron
Indexable insert tooling for newbies Dan S Mini Lathe 11 12-30-2006 05:02 AM
Insert Milling Tools? Joseph Souza General Metalwork Discussion 11 10-18-2006 08:26 PM
Anyone make their own lathe insert toolholders? Zumba General Metalwork Discussion 2 05-16-2006 01:42 AM
INsert Molding PC7 Moldmaking 3 04-15-2006 06:56 AM
Identify this insert Cold Fusion General Metalwork Discussion 7 08-27-2005 09:56 PM
