Old 02-12-2007, 01:22 PM
nebyeh is on a distinguished road
Milling aluminum
I have been milling aluminum with my diy cnc trimmer router, and it seems to do fine using a 1/4" carbide 4 flute end mill, cutting the full width and taking a .05 depth of cut, at least when I have the router cut left to right, and also using the G02 command, but if I try using the G03 command or cutting from right to left the bit will veer off and dig itself down into the workpiece, what is the difference between the different directions that is causing this?
Old 02-12-2007, 10:56 PM
Gold Member
Caprirs is on a distinguished road
Sounds like climb milling versus conventional milling. The difference is with climb milling, the tool is effectively trying to pull itself into/along the cut. This is the preferred way if everything is rigid like on bigger mills. I'm guessing your router isn't sufficiently stiff to keep the tool from pulling itself into the material.
Milling Aluminum InventIt General Metalwork Discussion 20 12-05-2011 07:20 PM
RFQ milling aluminum 25 pieces to start Jim Girardeau Employment Opportunity 5 02-23-2007 09:25 AM
RFQ: aluminum milling and steel turning stanglou Employment Opportunity 2 01-21-2007 08:09 PM
Milling holes in Aluminum walter General Metalwork Discussion 16 02-14-2006 10:58 AM
Interested? in milling a logo in aluminum for $$$? midevilone Employment Opportunity 1 04-13-2005 12:49 AM
