Old 02-10-2007, 09:55 AM
jackson's Avatar
jackson is on a distinguished road
GUHRING special drills
Guhring has these spcial drills that are a 2 flute step drill they are not twist or spiral they are strait flutes i was wondering if anyone had ever tried these or know of some like them. I'm curently using a half round drill and it is working great i run it 21,000 rpm's F60. ipm's it steps from .192,.1575, to .125 i tried a twist and it made about 500 parts wich is 3000 holes before breaking. i drill 48 holes in about 1.5 mins the reason for the quetion is being a half round it is not balanced and i'm worried about the life of the bearing in the speeder at that rpm
the recomendation is no more than 12,500 rpms on non balanced drills any ideas
Thank you
individual who perceives a solution and is willing to take command. Very often, that individual is crazy.
Old 02-12-2007, 06:23 AM
cdlenterprises is on a distinguished road
I'm not sure about your application put Guring stuff is usually top shelf. My experience is if they say it will do something it most likely will. I'd get the rep in and have him do a test for you. Can't hurt to try...
I don't know much about anything but I know a little about everything....
Old 02-12-2007, 12:43 PM
jackson's Avatar
well i sent my rep the specifics of what i need i will find out the cost of the drills before i go any further
parabolic drills Machine1 Hard and High Speed Machining 18 06-11-2008 09:22 PM
PCB Drills aggie_67 General Electronics Discussion 7 03-07-2007 09:47 AM
Iscar Cam Drills jackson General Metalwork Discussion 1 01-15-2007 06:52 PM
Guhring Solid Carbide Drills bma137 General Metalwork Discussion 14 08-16-2006 07:13 PM
carbide drills MBG General Metalwork Discussion 30 10-23-2005 08:03 AM
