Old 02-07-2007, 07:04 PM
norvil1 is on a distinguished road
Question detent balls
what is the best way or tool for installing detent balls and springs? have never done this and i would like to know the best way to do this. thanks.
Old 02-07-2007, 08:59 PM
HuFlungDung's Avatar
Moderator
Where are you installing them? Transmission shift rails, or what?
Old 02-07-2007, 11:28 PM
NinerSevenTango is on a distinguished road
Buy the threaded ones from McMaster-Carr and screw them in. Saves mucho screwing around! If you can make them fit in whatever it is you are building.
--97T--
Old 02-08-2007, 05:15 PM
Exclamation
huflung i will be using on firearms or flat surfaces to position levers. after drilling the hole and inserting a spring and ball,what tool is used to close the hole to capture the ball in place?
Old 02-08-2007, 05:43 PM
I drew a little sketch. I used a sort of inside out punch, the red thing in the sketch, on aluminum. It was just made out of drill rod and hardened. This would probably work in soft steel but you might chip the end on a few before getting the hardening and tempering correct.. The tricky part was getting it centered but it would be easy to make a guide that you clamp onto the part.
Old 02-08-2007, 06:14 PM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
If you wish to do more net searches; the process (as Geof shows) is usually called "staking"
www.integratedmechanical.ca
Old 02-08-2007, 06:18 PM
Thanks, now I see the name I remember it . Funny how that works.
Old 02-08-2007, 06:51 PM
widgitmaster's Avatar
Gold Member
widgitmaster is on a distinguished road
I have used large ball bearings!
Just place them over the hole and hit them with a hammer! It will swage a nice looking chamfer around the hole opening, and keep the balls from popping out!
Use a ball twice the hole diameter!
Widgit
How many balls in nut? phantomcow2 Linear and Rotary Motion 10 04-19-2007 10:30 AM
I need 1 7/8" aluminum balls carbidecraters Employment Opportunity 4 12-15-2006 01:14 PM
Lost Balls for THK HSR15 Help planekrazie Linear and Rotary Motion 2 08-13-2006 09:14 PM
Ballnuts: Do you really need all the balls? geohot Linear and Rotary Motion 3 12-27-2005 12:34 AM
Loaded or unloaded balls? CNCadmin General Metal Working Machines 4 04-01-2003 01:41 PM
