| What kind of screw and thrust bearing are you testing? Is this a precision ground ballscrew and precision thrust bearing block? There are certainly instances where screw wear needs to be mapped for different positions along its length. A cnc controller then automatically adjusts the backlash for additional error due to non-periodic wear of the mechanical components, and these adjustments would be location specific on the machine.
| Ok if i take out backlash move left by 0.1" my dial indicates 0.982" i can repeat this quite close, so is this screw mapping or steps per inch?? 10tpi screw microstepping 1/16's 32000 steps , i get different results on the x and y |
| If it seems to be relatively uniform everywhere, then .018 would be the backlash setting. That is a very large amount for a 10 tpi screw. I would make every attempt to eliminate looseness in all thrust shoulders, and maybe make a springloaded nut, in an attempt to keep the screw bearing always on the same side of the nut. A new, tighter nut would also be good, or a double nut, with a fixed shimmed distance between them. You should be able to reduce a uniform backlash down to a thousandth or two.
| Servo idea - elimated backlash - zero backlash ! | synthetiklone | Linear and Rotary Motion | 6 | 12-06-2006 01:35 PM |
| Backlash Question | Kazsaw | Haas Mills | 3 | 08-14-2006 05:03 PM |
| Backlash Question | scratch_6057 | DIY-CNC Router Table Machines | 3 | 06-15-2006 03:32 PM |
| Backlash Question. V4.0.1 | BMaynard | TurboCNC | 3 | 04-12-2006 06:38 AM |
| backlash question | arsenix | Bridgeport and Hardinge Mills | 4 | 11-01-2005 12:25 PM |
