I'm trying to figure out how I can make this. The center hole is only about 1/16" in diameter but it has a flat side for a "key." Perhaps a broach? I really just don't know. And of course, just to add to the complexity, it has to be perfectly centered. I thought about a very tiny end mill (1/32?), but the part I'm replacing has no internal radius on the flat part, and this wouldn't be ideal for preventing stripping (it would lose quite a bit of leverage if it had any radius in the inside corners). I'm attaching a pic to help explain what I'm trying to do. |
| How many do you have to make? If only one, lay out the hole with dykem, drill a hole in the middle and get after it with a file. With enough care, you should be able to do a fine job. Especially if the shaft is available for trial fits as you go. I'd think you'd need at least two small files: a half round and a traingular. You'd probably want to grind a safety edge on one flat side of each file. |
| 1,000 +/- a few. Way too many to do by hand and more importantly it has to be as precise and with the closest tolerance as possible. I don't have a specific figure for the allowable tolerance...just the tighter, the better. The part I'm trying to replace has a little slop to it and that's a major part of the upgrade I'm hoping to able to offer. |
| wire edm is the best, however slow. you could also adjust the corners with small u-cuts and then you could interpolate on a cnc mill. Any questions i am more than happy to send u a sketch of your part with my ideas added to it. richard.brodeur@niagaratools.com |
What's the mat'l.....how thick? If hard stack a bunch of plates and tack weld together, Drill some holes for threading and wire the complete profile. Or burn with a sinker EDM the center feature. I've done similar parts out of 6061 AL by steping down to a small diameter end mill. It's probably for a shaft, so a small undercut (over-extending the flat) would probably be permissable if the diameter is held tight. |
| My idea maybe not the way to go but I give it a try anyway. I think with the long rod EDM the center contour, hold in the chuck lathe face then cutoff .01 plus to length, then flycut cutoff end to length. With rod match the ID contour hold in the chuck, then turn OD. Just my $.02
__________________ The best way to learn is trial error. |
| It's made from aluminum. It's dimensions are about 1" in diameter, about 3/8 thick and as much in-between material is removed as possible for weight reduction (similar to a billet wheel, but really small). I'd like to be able to make them myself if possible. I guess I'm hoping someone makes a key broach in that shape. I don't have an EDM, but I do have a CNC and assorted other shop tools. So I guess I'm adding a wrinkle to the design...I need the closest tolerances possible...but I need to be able to do them in just a couple minutes each for the lowest cost possible. You know, I want everything...and I want it for nothing |
#10
I like that Idea....Or how about finish turn a long section with a rough drilled hole (makes burning faster), then burn.....then part.....the only issue would be burrs at parting. |
#11
| If the part thichness is within 6 mm, My opinion is to punch it out. for very precise job, u can make it with two punches, rough one, make 1 mm smaller then finish and finish it with another die. It will also reduce ur working cost. But dies cost must bear. |
#12
If you have a CNC VMC.....then have you ever stripped a job? I used to mount 3 Kurt Vices with aluminum soft jaws. then mill a .1 deep step on solid and moveable jaws. If I had 30" of travel I would cut a 28 or so long bar (In your case 1.125 X .5) face top, mill profile (as many times that will fit in 30"). Drill, mill center feature, step down to small diameter EM. Then deburr. Stack the strips up. Then Op2.....Mill in circular pockets the same width apart as your parts in the strip, Clamp lightly, hit down with a dead-blow, tighten vice, Flycut, Deburr, parts complete......In fact, in Op1 I would pre-drill the corners of your "D" so you don't have to deal with EM deflection. |
