Old 02-04-2007, 11:27 PM
kokelol is on a distinguished road
Cool Potts drill grinding jig
Help I am looking for drawings or plans to make a Potts drill grinding jig
This jig is probably an English or British made attachment
Tnx KOKELOL
Old 07-11-2007, 03:53 PM
Piper2007 is on a distinguished road
Hi Kokelol,
I found your post while also looking for plans for the Potts! I liked the Forum so much I joined and this is my first post.
The Potts drill grinding jig was ( I am fairly sure ) described in the Model Engineer magazine along with a simple drilling spindle for a lathe cross slide which also bore the name Potts.
There is a drill jig listed in the plans service run by the publishers of the magazine and although it is a Potts, it is very similar and it was designed by a chap called Ian Bradley who I think also wrote under the pseudonym of Duplex.
Try this link anyway and see if that jig will do what you want:
http://www.myhobbystore.com/ProductD...c-13e89869c310
Best of luck and let us know if you do come across the original thing.
Regards,
Piper2007
Old 01-08-2009, 05:08 PM
Drill Sharpener is on a distinguished road
drill sharpener
hi..i have a drill sharpening arm the works off a bench grinder.
im making and selling them so if you are interested let me know. check my page for photos and video. cheers
kevin
Old 01-08-2009, 05:39 PM
Potts Drill grinding Jig - Source for drawings & Castings
Hi Kevin,
Since starting this thread I have discovered a source for the drawings and castings for the Potts Jig. This is the only way to sharpen drills as no other device adjusts the backoff angle correctly for the size of drill.
http://www.hemingwaykits.com/
Follow the above link for more details, I can recommend Hemingway. I have bought this kit and the drawings ( in AutoCAD Inventor) are excellent. I have yet to complete the machining.
By the way you didn't put the link in for your video/photos.
Regards,
Andrew
Old 01-08-2009, 05:52 PM
Red face
Originally Posted by Piper2007 View Post
Hi Kevin,
Regards,
Andrew
hey andrew yes im sorry.. i wasnt expecting such a quick response to my message..i will upload photos and a video tomoro..please let me know what you think of the product..cheers.
kevin
Old 01-09-2009, 12:57 PM
easy cheap and effective twist drill bit sharpening
hi i have made a video of my drill sharpening kit.
here are a few photos also, the url for youtube is below..thanks..all comments much appreciated.
we are starting to manufacture these on a small scale so
watch this space for a website etc!!
cheers
kevin
ID:	73207   Click image for larger version
ID:	73208   Click image for larger version
ID:	73209   Click image for larger version
ID:	73211   Click image for larger version
Spade Drill Does Work in Aluminum; Big Hole Boring on Drill Press. Geof General Metalwork Discussion 47 02-01-2008 01:32 PM
Drill holes with end mill or twist drill ? Argofanatic General Metalwork Discussion 15 12-29-2006 10:05 PM
Carbide drill VS indexable drill kalmah General Metalwork Discussion 8 11-08-2006 06:48 AM
Can I drill AISI 1020 plate steel with a drill bit? Apples General Metalwork Discussion 2 02-01-2006 11:15 AM
Drill Press or Mill/Drill? cbcnc Benchtop Machines 2 03-05-2005 05:03 PM
