| View Poll Results: Did you find this information usefull? | |||
| Yes I did! | | 21 | 95.45% |
| No I didn't | | 1 | 4.55% |
| Voters: 22. You may not vote on this poll | |||
First of all, reamers only cut on the outer tip, not on the sides! If a reamer is cutting a few tenths big, run the spindle in reverse and gently hold a fine white Arkansas stone or Norbide stick against the flutes. This will wear the OD slightly and make the reamer cut smaller! This works on either HSS, Cobalt, or Carbide reamers. If a HSS or Cobalt reamer is cutting too small, take a new sharp carbide lathe tool bit, and carefully scrape the inside of the flutes, pushing the burr outward and increasing the diameter a few tenths! This technique only works once on a new reamer! There are many opinions about controlling reamers by increasing & decreasing RPM and feed rates, as well as the amount of material being removed, last but not least the material your cutting. Experience is the best teacher! WidgitMaster Last edited by widgitmaster; 02-04-2007 at 09:25 PM. Reason: added pics |
Here is a nice VIDEO of me drilling and reaming a .0623 Dia cross hole in a 303-SS pin .125 diameter. The pin was mounted in a 1/8" 5C collet, in an indexing fixture held in the vise on my mill! 1st I used a 1/8 center drill to peck at the part, this ensure the point doesn't deflect of the radius surface. Then I drilled a .0595 dia. through hole, followed by a reamer! The VIDEO is 2.5 meg BIG, so be patient as it loads! |
| band saw welding techniques? | tmt_92021 | General Metalwork Discussion | 7 | 06-02-2010 12:32 PM |
| plunge roughing techniques? | championp | Surfcam | 11 | 02-05-2007 06:11 PM |
| anybody compare HT finecut tips to TD 1Torch tips for dross? | Knut | CNC Plasma and Waterjet Machines | 0 | 09-29-2006 01:17 PM |
| Reference for Engraving Techniques | bill south | General CAM Discussion | 1 | 07-31-2006 01:14 PM |
| Drafts: Tips for vendors and tips for RFQ writers... | InspirationTool | Employment Opportunity | 3 | 12-20-2005 08:44 PM |
