The shop I work at just finished cutting some stainless. I looked up the Heat Number and the certs and it is defined as 17-4PH H1150. Am I missing something? I thought 17 - 4PH is different than 17-4 H1150.. Anyways. I'm going to use the bar ends to turn out some shifters to mess around with some ideas, and I was wondering what cutting speed I need to use? And, will I be ok with using a G50 of 1800? After turning, I'm planning on getting them chromed, or powder coated. So, what surface finish do I need to produce? Would a feed of .006 be ok, or do I need to go rougher? And my last question... is it imperative that I use an insert specifically for stainless, or can I use a standard coated carbide for turning 4140 HTSR and get by with it? |
| Looks like you got some 17-4 with an 1150 degree solution and age temper. 17-4 can be first tumbled and then electropolish finished and essentially look like it is chrome plated when done properly. Plan on a multi-stage tumble and finish if you have a rough as a cobb part to begin with. Basically, the smoother you cut/finishe it, the less polishing will be needed to affect a smooth/shiney surface on the finished part. Should you chrome plate ANYTHING, the chrome merely provides the shiney surface. The chrome will NOT fill in holse or scratches of a poorly prepared and/or unpolished surface. Basically, the nicer you finish your part, the better it will look after chroming/plating. Check out Carpenter Technology (Cartech) as they used to have a handbook on precipitation hardening stainless (which is what 17-4 is) and it gave machining guidelines. We've used HSS and/or carbide to cut and drill it but that ultimately depends on the temper. |
| Your gonna hate me for this | SMT-OPERATOR | RC Robotics & Autonomous Robots | 11 | 05-29-2007 04:17 PM |
| I'm gonna loose it!! | k-linkz | Stepper Motors and Drives | 3 | 12-27-2006 07:15 PM |
| custom shifter knob | Jacook888 | Employment Opportunity | 3 | 08-22-2005 06:08 PM |
| You're gonna laugh! | CNCadmin | CNCzone Club House | 4 | 08-12-2004 06:35 PM |
