Old 02-04-2007, 02:16 AM
kenlambert's Avatar
kenlambert is on a distinguished road
Degree wheel
Does any one have a drawing or program for a degree wheel. I want to cut one on my cnc mill . I have downloaded some pics of some free drawings but have a problem getting them in my cad so as to edit and make the code , I have bobcad 20
thanks Kenneth
web-www.lambertsrc.com
Learning CNC
Old 02-04-2007, 02:23 AM
Pres is on a distinguished road
What diameter wheel are you desiring?
What resolution?
Old 02-04-2007, 11:47 AM
kenlambert's Avatar
I want to cut one 4-6 "
If I could figure out how to draw the scale would be even better
thanks Kenneth
Learning CNC
Old 02-04-2007, 11:51 AM
RLC RLC is offline
RLC is on a distinguished road
This is a 4", will this work for you?
Robert
Old 02-04-2007, 06:54 PM
kenlambert's Avatar
that will work perfect thanks and how did you draw this up?
thanks Kenneth
Learning CNC
Old 02-04-2007, 09:30 PM
RLC RLC is offline
I first drew two circles with X"0" Y"0", one was smaller than the other (1/4” or so), then I divided both circles into 360 parts (change > break > divide). I then changed colors and drew 5 join lines from the ends of the top arc segments the first one being the “0” or top line and then 4 more to the right of the circle at the end of each arc segment. When all 5 were done I selected by color everything except the lines (degree marks) and deleted them. Then I placed a point at 50% of the line on lines 2 thru 4, then trimmed the line to the point. You should have 5 lines drawn 1* apart from each other and 4 points on the center lines, removed the points, then select all. Then select change, then rotate and make sure it is by coordinates and around axis “Z” is 5 and the scale is 1, and “make a copy” is checked, in the number of copies type 72 and hit ok…hope this made sense and helps
Robert
Old 02-04-2007, 10:16 PM
kenlambert's Avatar
thanks
thanks Kenneth
Learning CNC
how do i obtain required degree steps? Syphonics Stepper Motors and Drives 3 01-07-2007 05:43 AM
45 degree bevel on angle iron Rypper DIY-CNC Router Table Machines 3 11-14-2006 01:00 AM
Marking a degree wheel tafc General Metalwork Discussion 4 09-16-2006 10:46 AM
90 degree radius bender Scratch Bending, Forging,Extrusion... 4 09-09-2006 01:57 PM
0.9 degree stepper. Use or not? jdholbrook Stepper Motors and Drives 6 05-28-2006 01:47 AM
