Question about calculations for worm gear hobbing... I'd like to try hobbing a few worm gears and would like to know how to calculate OD etc. I've found the GearSpec program from W.M. Berg http://www.wmberg.com/ but the deal is, I'd like to use a 1/10 pitch .500" Acme screw for the worm. I know this isn't a true worm, so the question is - is the data provided by this program close enough to create a servicable worm gear using the Acme threaded rod? PDF attached with worm gear data |
| Dfennell, "I'd like to use a 1/10 pitch .500" Acme screw for the worm. I know this isn't a true worm,". It is a true worm! The Berg Data is for Fine pitch worms, the P.A. is fixed at 20*, You need Industrial wormgearing, Machinery's Handbook has the equations, P.A.'s range from 14.5*(Acme Thread form) to 30*, So you have to crunch a few numbers & you're ready to do it! Got more medical appointments, will be back to check on you, Happy Worming! Cheers Les H. |
| The chart looks about right to me. One thing to help avoid confusion: the description of diametral pitch in your chart is listed as 1/10" pitch. That is actually your circular pitch. The equivalent diametral pitch for that is about 31.416 Dp. Just telling you this in case you get a notion to purchase some kind of tooling and get perplexed when it it 3.14159 times bigger than you expected
| "Fake" worm gear | Zathras | General Metalwork Discussion | 13 | 10-17-2009 09:58 PM |
| Zero backlash worm gear idea. | ynneb | Mechanical Calculations/Engineering Design | 14 | 07-31-2009 01:25 PM |
| gear hobbing.... | Chris D | General Metalwork Discussion | 23 | 02-27-2009 02:41 AM |
| newbie question about hobbing | MBG | General Metalwork Discussion | 7 | 02-26-2005 09:31 PM |
| question on gear rack | wired | DIY-CNC Router Table Machines | 7 | 01-08-2005 02:37 PM |
