Results 1 to 7 of 7
Thread: cnc lathe Cartesian-to-polar interpolation
    Apr 2005
    Hi
    I work on a lathe at work that has live tooling but it has a option of Cartesian-to-polar interpolation, programming x and y on the lathe which converts it to x and c. but the option is not installed. does anyone know or have a macro that can do Cartesian-to-polar interpolation ?
    thanks
    Registered CNCRim's Avatar
    Feb 2006
    I think what you need is G12.1/G112, It already build in the machine.
    Apr 2005
    I tried g12 and g12.1 but they didnt work. never tried g112
    have to try it mon
    Feb 2006
    What is the branch of your machine and what try of control?
    If you did tried G12.1, then I assume G112 will trip same alarm. I suspect the parameter is not set on for Polar or the M-code is need before excute G12.1.
    Apr 2005
    it is a colchester CNC650 and has a fanuc 10t controller
    thanks
    Apr 2005
    I tried G12, G12.1 G112 and I get a alarm (ps010).
    in the g-code list in the users manual does not have a g12 or g12.1 in it but there is a section in the manual about g12.1
    Feb 2006
    Yeah, I think you need to call application support and ask them how to turn milling polar. Then the machine should fine, G12.1 is standard for full c-axis.
    1. G12.1 Polar Milling
      By JimW in forum Surfcam
      Last Post: 01-23-2010, 11:56 PM
    2. How do you use polar interpolation
      By positiverake in forum G-Code Programing
      Last Post: 12-07-2006, 09:59 PM
    3. Uni-Polar or Bi-Polar, or does it matter?
      By imagineer in forum Stepper Motors and Drives
      Last Post: 12-05-2006, 11:53 AM
    4. Electronic Utopia Bi-Polar Board (or other Bi-Polar boards)
      By ranman in forum Stepper Motors and Drives
      Last Post: 05-29-2005, 09:25 AM
    5. Anyone used this bi-polar stepper controler?
      By Stevie in forum General Electronics Discussion
      Last Post: 03-06-2004, 11:17 PM
