Old 01-25-2007, 05:05 PM
wrenchcruncher is on a distinguished road
threading
I bought a new 14x40 metal lathe a year ago and t tried to do my first threading job on this machine, a thread of 13 tpi. The thread turned out uniform & clean but my pitch guage won't fit uniformally, it looks like it isn't cutting 13 tpi but more like 12.5 tpi ?. I know the gearing & speeds are correct. any ideas would be appreciated.
Old 01-25-2007, 05:11 PM
jackson's Avatar
jackson is on a distinguished road
what setting on your dial are you using
individual who perceives a solution and is willing to take command. Very often, that individual is crazy.
Old 01-25-2007, 05:20 PM
I tried useing #1 consistantly and it still did the same thing.
Old 01-25-2007, 05:22 PM
jackson's Avatar
try using 3 some lathes iv worked on do better on a differnt setting
Old 01-25-2007, 05:29 PM
Thanks I will try it. Have you ran into this same problem?.
Old 01-25-2007, 05:36 PM
jackson's Avatar
oh yes iv acualy had a lathe that you had to start the feed let get to the end of the thread then hand wheel it out and let it feed back because it would not repeat
Old 01-25-2007, 06:04 PM
Willbird is on a distinguished road
As long as you follow the directions for the thread dial it should not matter what NUMBER you engage on. IE many will say something like "Even numbered threads any line, odd numbered threads any numbered line...fractional threads the SAME line every time" Especially if you hit the line every time and the thread followed every time, choosing another line on the thread dila will do nothing different.
I do know that SOME lathes do have a change gear inside the end of the machine that you must swap to get metric threads....maybe that is not setup properly.
I also saw a lathe that had just ONE thread lead out of all of them that was not correct, it was some inexpensive czech lathe or such. An easy one to check without cutting a full thread is 8 TPI, just run a scratch cut deep enough to see, and use a ruler to count the threads in 1"....or just look to see if they all hit the 1/8 lines :-)....4 and 16 are also easy to do the same thing with. For other threads I will usually do the same scratch cut and set my dial calipers to the distance 4 threads should cover, and then measure from scratch to scratch and see if there are 4 threads properly fitting in there.
Bill
Old 01-26-2007, 08:40 AM
jackson's Avatar
Originally Posted by Willbird View Post
As long as you follow the directions for the thread dial it should not matter what NUMBER you engage on. IE many will say something like "Even numbered threads any line, odd numbered threads any numbered line...fractional threads the SAME line every time" Especially if you hit the line every time and the thread followed every time, choosing another line on the thread dila will do nothing different.Bill
your right it shouldnt matter but somtimes it does, trust me i'v been there and its a pain in the a$$ but some lathes are like that (mostly come acrossed it in older ones) and the gear is one thing, good call
Old 01-26-2007, 07:40 PM
Kiwi is on a distinguished road
Is your lathe a imperial lathe (lead screw, cross and compound dials.)?
If it's a metric lathe you need a gearwheel with 127 teeth to convert to imperial.
I have a metric lathe which dosen't have a 127 gear and when cutting imperial threads the TPI are not exactly correct.
Threading MDF Me2 FAQ of CNC Machine building 5 05-26-2011 01:08 PM
ID Threading Toddjones G-Code Programing 6 05-24-2009 01:46 PM
Threading brtlatjgt General Metalwork Discussion 2 05-11-2006 11:08 AM
CNC Threading metalworker Mini Lathe 1 10-31-2004 01:14 PM
Threading Help Please Donovan General Metalwork Discussion 12 10-31-2004 12:22 AM
