Old 01-15-2007, 05:28 PM
jackson's Avatar
jackson is on a distinguished road
Iscar Cam Drills
I have been using these drills now for about two months now and i think there great is any one else using them, and have you used any thing like them and how do they compare, in quality, price, and avalibility.
individual who perceives a solution and is willing to take command. Very often, that individual is crazy.
Old 01-15-2007, 07:52 PM
GaryCorlew's Avatar
GaryCorlew is on a distinguished road
I use them a lot!! I also use spade drills for bigger holes 1.5" and up mostly for deep drilling. When you think about price you also have to factor in the machine time and that will make the cost a lot less when comparing cam drills to regular drills also they are alot stiffer so you do not have to worry about them walking on you. I usually use them for holes that will be milled to a certian size. The cam drill will be about .01 less than the final size so I make just one trip around, I would not try that with a regular drill even if it was a jobber length. For drilling big holes or deep holes I usually go with a spade drill, even faster than a spade drill. Once you go to either one of these you will not want to use anything else!!
