Old 12-29-2006, 05:30 PM
Jim Mill is on a distinguished road
Question Alternative Material
I would like to know what type of material to practice on other then alumunium, to keep cost down on my 3 axis cnc mill?
Any advice would be greatly appreciated!
Thank you,
Jim Mill
Old 12-29-2006, 07:06 PM
widgitmaster's Avatar
Gold Member
widgitmaster is on a distinguished road
try using 12L14 leaded steel, cuts really nice!
also try plexiglas, it comes in all thicknesses too
Old 12-29-2006, 07:11 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
mdf would work well , you can glue pieces together to get larger stock size if you need ,one sheet is cheap and would go a long way
safe on tools as well
Old 12-29-2006, 07:40 PM
Widgitmaster and Detsap. I thank you for your quick reply to my inquiry.
Is mdf (mild dentisy foam ) ? If I'm in error please correct.
Again, Thank you,
Jim Mill
Old 12-29-2006, 07:56 PM
Gold Member
MDF - Medium density fibre board - a man made material used as an alternative to wood.
Old 12-30-2006, 03:08 PM
NC Cams is on a distinguished road
Bar soap for small parts, 4x4 wood chunks glued together for big "billets".
