I am desiging a part that needs to have a volume milled out (~7.8" long, ~5.5" wide , and ~3.4" deep). I am assuming that a 1" diameter end mill will be used and the material is 7075. Is this a reasonable depth to mill out? Will I need to look for a shop with special tooling?
Thanks in advance for your help/comments.
LinkBack URL
About LinkBacks
Really, it's not the easiest cut in the world but I've seen much worse. You shouldn't have a problem finding someone to make it. If you do, then there are a lot of really, really busy machine shops out there that don't need the work.
