Old 01-31-2004, 11:37 AM
foamcutter is on a distinguished road
Drilling Chrome Steel Help please
I need a little help. I have an idea but it involves drilling and tapping threads in Chrome Steel. They tell me it has a hardness rating of Rc60. I don't know much about this but I'm thinking that's going to be really tough to drill and tap. Needing to bottom tap hole about .5 to .75 in deep. Anyone got any ideas? Thanks Ron
Old 01-31-2004, 03:30 PM
keithorr is on a distinguished road
Machine when annealed, and then harden. Rockwell C60 is getting up there. I make shear blades from D2 that gets hardened to C61 after machining, but I back it down with a temper to C55ish, according to the manufacturers instructions.
One blade of each pair is drilled and taped before hardening. The only thing I can do after hardening is chase the threads to remove scale/carbon and the final grind on the cutting edges.
Old 01-31-2004, 08:17 PM
Keithorr,
Thanks for the reply. These are already hard. They are 1.5 inch balls. Could I anneal them , drill and thread and then harden again? I have a small electric furnace that I melt and cast aluminum with that will get up around 1200 degrees. Would that be enough to anneal? Then drill and tap. Put back in furnace and heat again and immerse in oil to temper? How much warping or out of roundness do you think I would get doing this?
Old 01-31-2004, 08:55 PM
Temperature and process depends on the alloy.
http://www.tndie.com/
Old 01-31-2004, 09:04 PM
HuFlungDung's Avatar
Moderator
Here is another thread on this sort of topic:
http://www.cnczone.com/showthread.ph...hardened+steel
Old 03-29-2004, 02:35 PM
castguy2003 is on a distinguished road
Be sure to get oversize taps designed for parts that are going to get hardened or you may be in for a big surprise.
Old 03-29-2004, 11:51 PM
TAB TAB is offline
TAB is on a distinguished road
I would suggest having the threads EDMed into the parts. This will cause the least distortion. If you temper and anneal the shape could be altered to such a point where the rods are no longer useable.
This may be expensive so only you will know if these parts are worth the cost.
Good luck.
Old 03-30-2004, 10:52 AM
Thanks for all the replies. I have come to the conclusion there must be a cheaper, better way to get where I want to go with this. Trying to drill and tap them is going to be an excersize in waisting time and the price of having someone EDM is too much. It was to be a cheap project, now it is simply waiting til I get a better idea. Thanks guys Ron
Old 03-31-2004, 01:05 AM
Konrad's Avatar
Konrad is on a distinguished road
You can try, heat up the balls to a cherry red, then put it in ashes, to cool it down slowly.
Then, see if you can file it!
To re - harden it, heat up again to a cherry red for a few min. then quench in oil.
Konrad
Old 04-01-2004, 02:27 AM
BT1 BT1 is offline
BT1 is on a distinguished road
Why not do your operations prior to hardening, then try chrome or nickel plating etc.
Machining Mild Steel georgebarr General Metal Working Machines 5 06-29-2005 07:54 PM
Drilling hardended steel - update DJ Morrow General Metalwork Discussion 3 11-29-2004 01:42 AM
CNC Router milling / drilling experience where I need help kaleem1 General Metalwork Discussion 0 10-06-2004 02:17 PM
why not steel? NeoMoses DIY-CNC Router Table Machines 15 09-11-2004 10:14 PM
Drilling hardened steel shaft Zephrant General Metal Working Machines 12 06-13-2003 04:42 PM
