Old 12-01-2006, 08:20 AM
gasho is on a distinguished road
please help with mastercam v9 post
Hi
I don’t have experience in writhing or modifying post processor for mastercam v9.1, so I am asking for help now.
#1 How to modify mpfan (generic Fanuc mill post) so do not post tool numbers and tool change any more.
#2 And in circular motions to post I & J instead of R
Any other tip regarding post processors for mastercam is more then welcome to
Thank you
Smple program used :
( 21/32 DRILL )
( DRILL 3/4-10 TAPED HOLES 4 PLC )
N368 G54 G17 G21 G69 G90
N370 G91 G30 W0
N372 G90 S350 M3
N374 G0 X-401.32 Y-381.
N376 G0 G30 Z0
N378 G43 H4 W100. M08
N380 G98 G83 W-34.408 Q2. R2. F76.200
N382 X-401.32 Y381.
N384 X401.32 Y381.
N386 X401.32 Y-381.
N388 G80 W100.
N390 M05
N392 G0 Z0 M09
N394 G49 G30 W0
N396 G91 G30 X0 Y0
N398 G90 M06 ------ m06 executes macro to stop and orient spindle
N400 M30 ------ toolchange done by operator
Old 12-01-2006, 08:53 AM
psychomill is on a distinguished road
To #1: You can eliminate T and M6 output but.... your machine doesn't need any tool changes? and you do you use different tools? You can suppress it in the post file but I want to understand how your output needs to be and what you're doing.
#2: Find this line near the beginning of your post file under "General Output Settings":
arcoutput : 1 #0 = IJK, 1 = R no sign, 2 = R signed neg. over 180
Change the value to "0" like this:
arcoutput : 0 #0 = IJK, 1 = R no sign, 2 = R signed neg. over 180
That should change your arc code.
NOTE: Post mods can get you in a stick real quick. Always back up your post file first before making any changes. That way you have something to go back to in case you edit something incorrectly.
It's just a part..... cutter still goes round and round....
