My advice would be to secure a sheet of maybe 1/2" or 3/4" MDF to the table and secure it with recessed screws, then skim cut the surface true and call it a day. This assumes you would use vacuum for hold down - vacuum will transfer through the MDF pretty well.
Otherwise, your floating head idea would work - there are commercial machines with such a system that use a nylon shoe to run on the material.
Scott
LinkBack URL
About LinkBacks
