Old 10-29-2006, 01:33 AM
macona is on a distinguished road
Machining a contol panel.
I am laying out my new control panel for my supermax and have a couple questions. I plan on using either 14ga or 12ga aluminum. I have to cut out a bunch of square holes for some of the existing pushbuttons I am reusing from the old control.
What should I use to cut these holes out? Endmill? I also thought I heard of a panel cutter bit but not sure.
What kind of bit is good for engraving?
Any good (cheap) software to create the gcode? Or just manually program the cuts and use something like deskengrave for the lettering?
Old 10-29-2006, 01:57 AM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
a small 2 flt em should work well for cutting out you holes , as far as engraving goes you could use a small ballnose or spotdrill ,center drill
Old 10-29-2006, 02:14 AM
307startup is on a distinguished road
I have seen aluminum cut with a mortise machine - the corners were square and even.
I like to use a carbide bit from a scribe to engrave with. The ones I have are 1/8' at the collet end...I get 5 "pencils" for $10 from MSC and the end unscrews just like an X-acto knife
