Old 01-13-2004, 06:12 PM
cbcnc is on a distinguished road
How can I cut Brass?
I have some projects in mind that I want to make out of brass.
Can it be cut on a tablesaw like aluminum? If so what kind of blade and lubrication would be the best?
Bandsaw? Chopsaw? Hacksaw?
If I was to mill out the shape on my CNC Router, what kind of milling cutters will work? Speeds, feeds, lubrication?
I know that this is kind of general but I've never really worked it before.
Thanks,
Chris
Old 01-13-2004, 06:52 PM
HomeCNC's Avatar
HomeCNC is on a distinguished road
You can cut non-ferious metal with your table saw. This means Aluminum, brass etc. Just use a carbide blade with about 60-80 teeth. Raise the blade all the way up so you are only cutting with the front of the blade and move slow. You don't need lubrication.
You can use a bandsaw, but it should be a metal cutting bandsaw because a wood cutting bandsaw moves to fast for a standard steel blade in the metal.
I would not use a chopsaw. Not because it could not work with a carbide blade, but because of the angle the blade will hit the metal. A chopsaw will be coming down with the full diameter of the blade hitting the metal. You want to limit the amount of teeth cutting the metal. This is why I raise the blade all the way up on a table saw.
Milling with a standard high speed mill or a carbide mill is fine. I have not used high RPM on metal because I use my milling machine for metal, and I have it set for 1800 RPM. I use a little spray of lub like WD-40 and it cuts great! If you plan to use a router for cutting brass then you will need to get info from someone else.
Jeff Davis (HomeCNC)
http://www.homecnc.info
Old 01-13-2004, 07:36 PM
Thanks Jeff,
I'll just put a piece on the tablesaw and try it. I have cut alot of aluminum on it without a problem. I find that with alum you get a better cut if you use a lube stick to prevent buildup on the blade. I'm using a standard 60 tooth carbide finishing blade. Someday, maybe soon, I will spend the $60 for a metal cutting blade.
As far as my bandsaw goes I can slow it down to 700 rpm or 5400 fpm. Do you think that is too fast?
My router is a Porter Cable trim router and goes at 30,000 rpm. I do have a speed control for it. I also have 1/4" and 1/8", 2 and 4 flute milling cutters.
Part of my problem is I don't have that much material to make scrap out of. But, here goes.
Chris
Old 01-13-2004, 08:54 PM
I was just looking closer at the numbers on my bandsaw and they are in fpm. So the slowest I can go is 700 fpm.
C
Kcam Cut depth 47MLB Kellyware CAM 6 01-18-2012 02:04 PM
Water cut?? Yepez CNC Plasma and Waterjet Machines 8 02-24-2010 09:23 AM
cut single, cut auto and cut all??? fastolds BobCad-Cam 3 10-06-2004 09:15 AM
PICS - BOAT HULL CUT WITH CNC ninewgt DIY-CNC Router Table Machines 16 08-02-2004 07:21 PM
Can you cut Al. with a wood bandsaw CactusChip General Metalwork Discussion 5 11-20-2003 04:45 PM
