Old 01-13-2004, 01:51 PM
Gold Member
creative_mind is on a distinguished road
Brass...why?
I've noticed that some things are built with brass material such as spindles, collars, handles, pulleys, and some other uses.
The question is, why is brass choosen for a particular use.
Some people say it's for decoration purposes, and others say it's stronger.
I need a clear reason.
Old 01-13-2004, 02:06 PM
Rekd's Avatar
Rekd is on a distinguished road
C360 - (Free Cutting Brass) Most common brass, excellent high speed machining operations and superior thread rolling and knurling characteristics. Easily soldered and brazed and has very good resistance to corrosion.
C464 - (Naval Brass) Excellent for hot forming and adapts well to hot forging and pressing. Good for drawing, forming, bending and heading. It is readily soldered, brazed and welded. Excellent corrosion resistance to seawater at all temperature ranges while maintaining strength and rigidity.
C485 - (Naval Brass Leaded) Similar to C464 the addition of lead to C485 provides a high degree of machinability. Good capacity for hot-forming but is not recommended for cold working. Can be readily brazed or soldered. Very good corrosion resistance to seawater.
HTH
'Rekd
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 05-25-2004, 01:27 AM
*Registered*
GWheeler is on a distinguished road
In a more general way, people like brass because it looks like gold but is much cheaper. It is weather resistant, and while it tarnishes or aquires a patina to a brownish color, that color is not unattractive either. In fact, "antique brass" color is a recognized finish color for things like architectural metalwork.
It holds up well in a marine environment, although it requires polishing if you want to keep it bright. It also seems a more "friendly" color than chrome or stainless steel and can have an old fashioned charm.
It is fairly easy to cast, and as mentioned above, easily machined types are available. Although brass alloyed with lead should not be used for use with drinking water these days. People should be careful as due to the health effects of lead. Copper oxide is not good for you either, but this is less of a problem apparently.
Brass availability Ken_Shea General Metalwork Discussion 4 12-26-2004 08:49 PM
Brass or aluminum gdl357 Steam Engines 3 08-27-2004 07:02 PM
Brass collets CNCadmin General Metal Working Machines 1 06-03-2004 12:31 AM
How can I cut Brass? cbcnc General Metalwork Discussion 3 01-13-2004 08:54 PM
Where to buy Brass? NeoMoses General Metalwork Discussion 3 10-05-2003 09:35 PM
