Hello Help, help please Can somebody give me some advice in how to make a .187 to .1875 hole in a 4140 steel, I have tried almost everything reamers boring bars and I'm having problems holding size. Also if somebody has experience in turning 4140 material, I'm havin problems braking the chips all I get is a very stringy chip thank you |
| For your stringy chip problem, what kind of tool are you using? For reaming, try carbide tipped or solid carbide reamers. Is your reamer running true? How much material are you leaving in the hole?
__________________ "It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet |
| Hey big mak for my chip problem I'm using a 55-deg diamond insert with a .015R for the hole problem I already try carbide reamers and my reamer it is running true. I tried boring it first and then ream but after running a few parts I get some parts undersize |
| What DOC are you using for the lathe tool? Feed? What speed and feed are you using for the reamer?
| As for turning, to break the chip, you must make sure that your depth of cut is larger that the tool nose radius. Your feed should be around 0.010"per rev. U using CNC for reaming? Try using G85 to Feed in feed out. How big is your hole before you are reaming it? I'd make sure its only around 0.182" or so.
#10
| with a swiss type machine you should be able to get a good aggressive feed on the turning part. As for the Reamed hole, areyou getting enough coolant to the tool? This can be tricky because with a small reamer the chips can fill the flutes and keep the coolant from getting to the cutting edges. Maybe just maybe try for the fun of it ream with G83 to let the chips come out and get coolant to the tip of the tool. It's easy for us to come up with ideas when we're here. Always a different story when you're at the machine.
#11
| well believed or not I can only go up to .007 feed rate before I get an overload alarm, I think the machine just don't have enough horse power to rip the material. As for the hole I'm going to give it a shot to the G83 ... tomorrow Thanks big mak for your help and Ideas if you have any other ones please post it I will check them tomorrow .. I think is time to give it a shot to try to sleep with all these ideas |
#12
| You might be work hardening the material. Are you using coolant? Keep the material cool during machining. It sounds like you may have work hardened your piece. Scott
__________________ Consistency is a good thing....unless you're consistently an idiot. |
