Old 09-27-2006, 08:46 AM
Terk is on a distinguished road
Workholding in the lathe
I need to machine the ends of some leadscrews and would like advise on how to protect the threads when turning. I'll be using a 3 jaw chuck (and a steady rest for the long screw).
Thanks for any tips you can give me.
Old 09-27-2006, 09:21 AM
*Registered User*
fpworks is on a distinguished road
G10 inserts on your jaws.
Make sure they are laterally keyed to your base jaws and use a threaded insert in the G10. (recommend keensert type)
Sorry about this recommendation if you are not doing very many parts!
Justin
Old 09-27-2006, 07:06 PM
ctate2000 is on a distinguished road
Buy or make a nut to hold in the jaws. Use another as a jam nut to secure. Collet would be perfect. If it is a true lead screw and has Acme or Square threads don't worry about it. Hold it in the jaws and go easy.
Old 09-27-2006, 08:55 PM
widgitmaster's Avatar
Gold Member
widgitmaster is on a distinguished road
just bore a hole in a short bar of aluminum, the exact diameter of the thread OD.
Then saw a slot through one wall, and insert the screw.
Close the 3 or 4 jaw chuck on the aluminum, it will clamp the thread as true as your bore!
Then you can machine the ends to suit your needs!
Eric
Old 09-27-2006, 09:00 PM
Gold Member
Oh yea,
Make a plug for the end of your spindle, with a loose bore for the screw to stay true to center, and do not let it protrude more than a foot, or it may bend and whip and hurt someone!
I use a piece of PVC pipe to support long bars on the end of my lathe!
A 2x4 stand with a hole at the same height as the spindle bore is all you need!
Old 09-27-2006, 09:19 PM
Gold Member
Adobe Machine is on a distinguished road
Check the thread " Manual to CNC lathe conversion. I have pictures of exactly what " Widgitmaster" has explained above. It works, its safe, its accurate.
If the material is hardned all the way through you should use a 1/64 radius cutter with a little positive rake, such as a CMNP or CNMG carbide insert,this will give you a good finish and decent depth of cut.
Adobe (old as dirt )
