Old 09-24-2006, 12:59 PM
turboboy is on a distinguished road
Easy way to find the radius?
Is there a easy way to figure out the radius on a part. I need to figure out the radius to transfer in to CAD program to cut the part.I dont have radius guages but wondered if theres a simple formula?. thanks for any help
Old 09-24-2006, 05:10 PM
quadbob is on a distinguished road
I don't know how big the part in question is but I have found that I use an edge finder. I start as close to one end of radius as possible and zero out the x axis. then I move the edge finder in y axis until it touches part. Lift up the z axis, and move 1/2 the diameter of edge finder toward part. Then zero out the y axis. Then I move a standard distance in x, say .500 and repeat the step for y. Basically you are looking for three points on a curve. When you input the 3 x and y values into a cam, assuming your cam can generate an arc from 3 points, it will give you the radius. I hope this is clear enough.
Old 09-24-2006, 09:26 PM
ctate2000 is on a distinguished road
Don't know what the part looks like. Guess, then print to scale from CAD/CAM and use as an overlay for comparison. Keep changing until it fits. Crude but effective.
Old 09-24-2006, 09:33 PM
miljnor's Avatar
S.N.A.F.U.
miljnor is on a distinguished road
if you have end mills and a machine you can make radius gauges.
thanks
Michael T.
"If you don't stand for something, chances are, you'll fall for anything!"
Old 09-24-2006, 11:17 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
if its small enough ,drill bits work well
Old 09-25-2006, 07:28 AM
*Registered User*
ChrisJ is on a distinguished road
Along the lines of Quadbob, here is a spreadsheet that I made a while ago. If you have three points on the arc, just input them in the spreadsheet and it will determine the center. Of course if you have a CAD program you can just draw a 3 point arc like Quadbob said.
Chris
Old 09-25-2006, 01:04 PM
ajl6549 is on a distinguished road
Do you have access to a cmm? If so...you know the rest.
Old 09-26-2006, 09:20 PM
widgitmaster's Avatar
Gold Member
widgitmaster is on a distinguished road
Finding the center of a radius is the 1st task, just use a dial indicator and sweep the radius until the dial stays at zero.
Next move over to the adjacent flat surface and get that distance!
Or use an edge finder to start from the flat surface, and then use the dial indicator to find center of the radius, thus the distance from center to the flat surface!
Eric
