  #13   Ban this user!
Old 12-28-2003, 10:54 PM
JWSmith is on a distinguished road
I buy most of my aluminum from Yarde Metals, the website is http://www.yarde.com/ Go to the drop zone on the menu on the left of the page.
Hope this helps.
John
  #14   Ban this user!
Old 12-28-2003, 11:53 PM
ezland00 is on a distinguished road
I recommend Speedy Metals. Low price and never over charge on shipping. their 888-744-4140 or SpeedyMtls@aol..com
  #15   Ban this user!
Old 12-29-2003, 09:01 AM
Chip Sweeper
Alan T. is on a distinguished road
Make friends with you local welding shop. Mine gives me all the scrap I want. I probably have 1500lbs of sheet, plate, box and extrusion.
Alan T.
  #16   Ban this user!
Old 12-30-2003, 08:05 AM
cadman's Avatar
cadman is on a distinguished road
Originally posted by bb99
OK, this may be a dumb question, but what do the numbers mean (e.g. aluminum 6061 and aluminum 5052)?
--bb99
Those numbers are alloy & temper designations. For wrought aluminum alloys, the 1st digit identifies the alloy type, the 2nd digit identifies the alloy variation, the 3rd & 4th digits are used to seperate that alloy from others in the same series (unique number). Temper designations are as follows:
F - as fabricated
O - annealed
H - strain hardened
W - solution heat treated
T - thermally treated
Cast aluminum designations are similar but there are differences.
  #17   Ban this user!
Old 12-30-2003, 10:28 AM
steveald is on a distinguished road
If you use structural channel for a gantry cross-member, keep in mind that the inside surfaces are not very precise, so if you are using THK style bearing rails and don't have the facilities to machine a flat surface in the channel, I would recommend using the outside surface to bolt the rails to. With Thomson style round rails it isn't quite so critical.
Steve
  #18   Ban this user!
Old 12-30-2003, 10:52 AM
Cold Fusion is on a distinguished road
I plan to use round linear rails.
Proud owner of a Series II Bridgeport.
  #19   Ban this user!
Old 12-30-2003, 01:11 PM
bb99 is on a distinguished road
Cold Fusion and cadman,
Thanks for the info! I keep learning something new from this site every day.
Happy New Year!
bb99
There are 10 types of people in this world; those that understand binary and those that don't.
  #20   Ban this user!
Old 12-30-2003, 05:59 PM
YGPM Alan T
  #21   Ban this user!
Old 01-27-2006, 12:37 PM
thaswell is on a distinguished road
Alum.
Find a company that does commercial door and window instalations. They have great scrap bins full of box and extrusions.
DIY Z axis 0 plate. It works perfect! balsaman DIY-CNC Router Table Machines 64 02-20-2010 10:52 PM
Aluminum: flat, bar, sheet, plate, tooling plate?????????? Dan S DIY-CNC Router Table Machines 12 06-28-2007 12:48 AM
How strong? (Linear rails, aluminum structure) WoodSnarfer Mechanical Calculations/Engineering Design 13 07-15-2005 11:29 AM
RFQ - Aluminum plate and spacers tjstraz Employment Opportunity 3 01-26-2005 08:25 PM
Cutting Large Diameter Holes in Aluminum Plate barkster General Metal Working Machines 18 04-07-2004 05:44 AM
