Try here:
http://www.metalsupermarkets.com
They have a location in Houston.
I've looked on ebay but shipping is a ton. Any suggestions?
Proud owner of a Series II Bridgeport.
Try here:
www.onlinemetals.com?
Other than that, try your local salvage yard, scrap dealer.
Eric
I wish it wouldn't crash.
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Ok, my next question is how thick of a plate should I get. I was looking at .500 inch for the end plates and gauntry. These are the parts that I want done in aluminum. http://cnczone.com/forums/attachment...=&postid=15999
1/2" is good for the endplates. If you can, use (or make) a "C" channel for the cross piece. Less flex.
Actually the side plates can benefit from that sort of design too. My sides can (and do) flex a little from the inertai of accel and decel.
Eric
What do you use to cut all of your aluminum plate? I'm assuming a table saw for bigger pieces. Will a band saw or jig work for any curved pieces I might be doing (with the proper blades of course).
I use my tables saw with a carbide blade. Read many places on the web said the used woodworking tools with carbide blades/cutters. I was leary, but now that I've done it, no big deal. Haven't tried a router yet.
Phil
p.s. the auction works site, my last order was $10 shipping on a $100 order of aluminum
Thanks a great site, I just bidded on some alum.
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
OK, this may be a dumb question, but what do the numbers mean (e.g. aluminum 6061 and aluminum 5052)?
--bb99
There are 10 types of people in this world; those that understand binary and those that don't.
They stand for the different grades of aluminum. 6061 is the standard grade. 7075 is stronger but slightly heavier.
