Old 09-11-2006, 08:50 AM
chipproducer's Avatar
chipproducer is on a distinguished road
Unhappy boring bar chatter
Hi Everyone,
I have started a job, and it went so well to start, but now the boring bar will not stop chattering. We tried changing the insert first, then moved on the speed and feed changes. We even tried changing the depth of cut to no avail.
If it would help, I could download pics of the parts.
Old 09-11-2006, 08:58 AM
Verfur is on a distinguished road
If possible shorten the lenght that the tool sticks out and use a positive type insert. General rule of thumb tool stick out less than 4* dia of said tool.
P.S. spindle bearings can play a big part.
Please post pics of Job and set up and materail type.
John
Old 09-11-2006, 09:22 AM
Walt@SGS.Inc is on a distinguished road
This boring bar, is it in a turning center or a machining center?
A little more information could be helpful.
What kind of material etc etc...Regards Walt
Old 09-11-2006, 09:29 AM
Sorry guys,
The material is 4130 steel. It is on a lathe and it is as short as it can be already.
Pics to follow soon.
Old 09-11-2006, 09:51 AM
can it be a bigger tool? and how thin a wall is the part?
Old 09-11-2006, 03:19 PM
Derek.C is on a distinguished road
Try boring from the inside out to try and get under the chatter also an old trick to stop vibration is to wrap the boring bar with elastic bands . Helps absorb the vibration , next step carbide bar.
Old 09-11-2006, 03:34 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
try some thick tapping oil , rather than flood coolant ,if that's what you are using , maybe try using a used insert that is in decent shape , sometimes a new insert will chatter until it has some wear on it
Old 09-12-2006, 07:58 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
Insert will need a very small nose radius to reduce cutter pressure - say .007 - .015"
www.integratedmechanical.ca
Old 09-12-2006, 09:24 PM
SeaSchell is on a distinguished road
Use a positive insert with minimum corner, wrap boring bar and part with rubber bands slow RPM
Dave Schell, SeaSchell Tackle Machining/Mfg./Design daschell2@cox.net 619 562-1835
Old 09-13-2006, 03:30 AM
rhino's Avatar
rhino is on a distinguished road
is the tool on center? how big is the hole you are boring? are you using the largest size boring bar possible? it can be a number of things.
On the other hand, You have different fingers.
  #11   Ban this user!
Old 09-13-2006, 08:24 AM
having problems posting pics.
The question has more to do with the fact that the first 15 pcs were perfect. Without changing anything, the chatter suddenly became a problem from one piece to the next. Now we can't get rid of it.
  #12   Ban this user!
Old 09-13-2006, 09:06 AM
Ah,
I to have run into this situation before on bar stock turnered out to be the material was a little difrent in the mid of the bar stock than on the ends go fiquire like to drove me nutttsssss!!! It could be a chemical dif or mechanical like its ben work hardend. I would try a slighty higher feed rate and or more depth of cut to keep the tool loaded. Also what type of tool (insert) are you using (I.E. CNMG 431, CCGX 430 exc.) pluss lead angle of. Oh and material condition.
Oh ahh is this a first op or 2nd and or 3rd? just asking cause I have seen parts change by diffrent ops, you know one guy may be more agressive than the other and or vis/versa just a thought.
John
