#13
| http://www1.mscdirect.com/CGI/NNSRIT...90938&PMT4NO=0 That one look good for a 3/8" endmill? I think so, but I am the newbie here ![]() http://www1.mscdirect.com/CGI/NNSRIT...90936&PMT4NO=0 For the 1/4" cutter? |
#16
| I am nowhere near good enough to offer any comment on the exact feed and speed that would be optimal, and I would easily trust in the advice previously given a few posts back. I do however, have the same Taig setup you will be using, and I thought I might point out that the numbers suggested also did assume a 2 to 3 horsepower spindle. Remember that you are using a very small mill, and will only have a 1/4 HP to play with using the stock setup. I seldom use mills above 1/8", and 1/4" mills often push the machine pretty hard. Keep the cuts light - copper will grab and seize that Taig up REAL easily. |
#17
| At least you can use a too-dull-for-copper-anymore tool on aluminum or stainless quite often. --------- Thread forming taps for helicoil....at MSC...duh. ![]() http://www.mscind.com/PDF/2005/260.pdf |
