Old 09-03-2006, 08:22 AM
bill south's Avatar
bill south is on a distinguished road
Question What Tool is Used for This????
Hey Ya'll. Greetings from South Carolina!!!! I have a simple question for the machinist on board. In the picture below, what kind of cutter was used to cut these serrations? Also, it appears that the point at the end of each serration is due to the tool being lifted out of the cut at the end (I hope I described that right!). Would you guess CNC or master machinist and what kind of tools can be used???
Thanks in advance.
Bill
billyjack
Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
Old 09-03-2006, 08:28 AM
fkaCarel is on a distinguished road
Looking at your picture?????, I would say they used dynamite. Quite universal tool.
Old 09-03-2006, 08:33 AM
bill south's Avatar
Oops!
billyjack
Old 09-03-2006, 08:46 AM
Minimal solution: pointed flycutter.
Old 09-03-2006, 10:24 AM
masterblaster is on a distinguished road
This was an included angle cutter. Probable a woodruff style end mill with the diameter to match the ends of the cuts, where when they stop the cut it leaves the pointed ends of the cuts. If it was a production piece, it was CNC. Can be done by hand by stepping over but much slower as the stop cut point will be different each line.
Old 09-03-2006, 11:45 AM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
threadmill
Old 09-03-2006, 11:56 AM
widgitmaster's Avatar
Gold Member
widgitmaster is on a distinguished road
Not ALL cutting tool are bought in the store, many old school machinists would prefer to free-hand a nice tool on a grinder, stone it to match a specific form or angle or radius! They can either be end cutting or horizontal side cutting single point tools, they usually cut with slow feed and speed but do the job most adequatly! It is a skill that should be learned by all machinists, and is rarely used in today's world of 3D automation!
The same cut can be done with a 1/16" carbide ball end mill (standard off the shelf cutter) and several passes at a time using high speed CNC machines to produce the desired form! So you can see there are many ways to skin a cat!
If you are doing a prototype, I would suggest the 1st procedure!
Eric
Old 09-03-2006, 12:01 PM
So that would be the dynamite?
Old 09-03-2006, 12:09 PM
dertsap's Avatar
Gold Member
threadmill would be the easyest and quickest , if you don't have one take a staight flt tap grind off the flutes except for one , two maybe three passes
Old 09-03-2006, 12:19 PM
How old school?
Old school? Hammer and chisel? Chasing tools? And your not going to get a V notch with a ball end mill no matter how good you are. Just messing with you. The thread miller and and included angle cutter are regular off the shelf cutters. You could even grind the slots, as long as you want to use the grinder to grind your own cutters. Form grinding of these parts is a popular approch.There are lots of ways to do it. It makes sense to look for the fastest and easist methods.
  #11   Ban this user!
Old 09-04-2006, 10:22 AM
stymye is on a distinguished road
I recall those type of cuts years ago with a small shaper.
don't see them much anymore
  #12   Ban this user!
Old 09-05-2006, 12:21 AM
big_mak is on a distinguished road
D-Bits from Micro 100, you can get them with a bunch of different included angles, we have them in 30, 60, 90, 100, 120 degrees, in a variety of diameters. You can get them from www.Travers.com
"It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet
