Old 09-02-2006, 09:25 PM
stymye is on a distinguished road
machining angle iron
Hi , my first post to the forum. I work for a machinery builder and use a bridgport mill , lathe and haas tm1 . I'm just getting used to cnc machining. And have begun using the TM1 more and more for basic milling
I did a search but could not find any specific answers to this question,
We often make parts from steel and aluminum angle iron. usually 2x2 up to 4x4 size pieces for various brackets. what is the best way to fixture and mill angle iron lengths and squareness without all the chattering and squealing. I'm a "decient" machinist but everytime I need to do this I just cringe. There has to be a secret to making this job easier.
thanks in advance
Old 09-02-2006, 11:01 PM
widgitmaster's Avatar
Gold Member
widgitmaster is on a distinguished road
Without knowing the dimensions of your parts, or the web thickness of the material it is difficult to answer your question!
If they are short, simply use an angle plate with three pins to locate from, and a hole under the part for a stud and strap! This will give you the 90 deg's, and some regidity for drilling and milling!
If you are contouring the sides of the angle, then there is little you can do other than turn the part upside down in a vise!
Got anay pictures?
Eric
Old 09-02-2006, 11:46 PM
thanks , I will take some pics tuesday to help describe the problems I'm having. the angle is usually 1/4 to 1/2 thick and 1" to 8" long we make all shapes and size brackets from it. but basically raw angle is machined into a nice bracket.however I don't make the same shapes often enough to create a specific fixture.
after cutting the angle to length, the ends have to be machined square .
I usually start scratching my head at this point.There are several ways I could clamp the part in a vise, one way requires a long EM that chatters like crazy because one leg of the angle iron is not in the vice and allowed to vibrate.
standing the angle iron verticle would require a spacer block and indicating the part.
I am wondering how most (more experienced than I) machinists fixture and mill the ends of angle iron.
Old 09-03-2006, 12:39 AM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
what i did for brackets we were making out of large angle iron was to clamp it in the vise and i made jacks out of some 1" square stock in which i cut out the width of the moving jaw ,added a set screw in the side and mounted it on the sliding jaw , it had multiple 1/2-13 hole to use bolts for jacks ,
finish cuts were .005 with a 3" facemill ,had no chatter , and the squareness was dead nuts as long as the jack screws were not too tight (obviously)
if chatter does become a problem use a mitee bite clamp or the sort to give it more rigidity
Old 09-03-2006, 09:13 AM
Gold Member
InspirationTool is on a distinguished road
Styme...
Can you machine the parts out of flat stock and then bend them in a bender or brake? It would be a heck of a lot faster.
Derstap...
Huh? Any chance for a picture or sketch? Maybe I need more coffee
-Jeff
Old 09-03-2006, 10:13 AM
Jeff, we are just building up our machine shop and unfortunately don't have a bender or brake.It will probably be a long time(if ever) before we have one that will bend 1/4 or larger material.
we are primarily a machine builder . That is trying to do as much machining in house as possible. (The Haas alone paid for itself in 6 mos.)
Unfortunately I'm just a rusty manual machinist from many years ago, trying to get back up to speed.alot of my past experience has slipped from memory.
Old 09-03-2006, 10:18 AM
Gold Member
Stymye...
You won't be able to do 8" wide on a bender, but if you do alot of 1" brackets, a Diacro #2 will work wonders on 1/4" steel and aluminum.
-Jeff
Old 09-03-2006, 11:11 AM
dertsap's Avatar
Gold Member
Originally Posted by InspirationTool View Post
Styme...
Derstap...
-Jeff
if you can punch it so that it has a snug fit ,by all means , for the rest of us who only have mills to make it on , it should take 15 -20 minutes to make if a guy know how to machine , i attached a simple scetch discluding the holes and actual size ,don t exactly feel like drawing right now , need more whiskey in my coffee
Old 09-03-2006, 12:26 PM
Gold Member
Oookay... so that jack base clamps to the moveable jaw, and then you clamp the angle so the horizontal leg overhangs the jack base, and you raise the screws to support the horizontal leg of the angle... but you don't stop the horizontal leg from lifting... is that correct?
-Jeff
Old 09-03-2006, 12:47 PM
dertsap's Avatar
Gold Member
miteeb bite ,if needed i didn t need it , ive cut complete outside radius and slots as well as bore and upheld squareness parallelism and surface finish with this simple method on 4 x 4 3/8 thk machined on all surfaces
  #11   Ban this user!
Old 09-03-2006, 02:25 PM
here is a bracket I made friday, I had to make 5 of them from 3x3 alum angle with a large web radius
that wasn't square to begin with....it took me half the day and I haven't milled the slots yet! I'm using a haas tm1.I have been programming and running cnc for about 5 weeks. so it's slow going right now. kinda learning as I go. luckly I have plenty time to make them but a half a day seems too long to square up 5 angle brackets.
I have a heck of a time figuring out how to hold the workpiece in the beginning to get things squared up from raw un-square angle iron
..I know this is probably basic to most of the members here
I admit to having have trouble thinking -outside the box
Old 09-03-2006, 02:46 PM
dertsap's Avatar
Gold Member
i was picturing a larger steel angle iron ,you should be able to do that quite easily with a nice set of alum step jaws , use an endmill to square up the inside a decent 3/4 endmill with a .25 stepdown ,at the right speed and feed you should have no problem , if chatter is a problem you can under cut the flutes so only .3 is in contact with the surface , or run a stone across the cutting edge to dull down the tool , a sharp tool isn't always the best and can actually cause the chatter
