I need to cut a .5 ball out of rod and leave a .125 shank. When I draw the cam drawing, I notice that no tool will leave the ball smooth because of the angle. The material will be aluminum or delrin. I was thinking I could make a second pass with something like a halfround cutter as used by routers to smooth it out completely. How can I do this, I only have a lathemaster benchtop lathe and it will be cnc'd |
| I don't think it will be a big problem since you have CAM system and you also have CNC, so my suggest to you is a neutral cutoff tool will be a nice application for you.
__________________ The best way to learn is trial error. |
| The downside with a form tool is the chatter will be huge if you use a half round ( or even a quarter round) on an 1/8 inch shank.
__________________ thanks Michael T. "If you don't stand for something, chances are, you'll fall for anything!" |
| Yep, that's what it will look like. Actually there will be a sphere on the other end of the shank as well. The part that is confusing to me is that Bobcad (which I am learning) asks you to define the point of the tool. So If I define the leading edge I can cut the leading edge of the sphere but the tail end is going to be jog'd to compensate for the tool width or radius. The only way I see it would work would be to cut one half the sphere with one (leading)edge of the tool and then have the program do a finish pass in the other direction using the other edge of the tool. Is that right? As far as the chatter, I figured that might be an issue. |
There is a way to make this part on a Lathe but it will require a special ground groove tool and holder with a specific method of cutting. If you would like PM me and I'll help you with it.
__________________ Toby D. "Imagination and Memory are but one thing, but for divers considerations have divers names" Schwarzwald (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) www.refractotech.com Last edited by tobyaxis; 09-02-2006 at 01:59 PM. |
Doing these in Delrin will be a real challenge because it is so flexible; brass would be my choice but aluminum is probably okay. What accuracy are you aiming for? Because the spheres have to be done using two tools and a second chucking for the second ball it might be tricky getting better than +/-0.0005". |
| Nice graph Geof. I couldn't get a clear method in posting this type of chart. This is the same and I think the only way to do this on a regular chucking lathe. I wonder if a special solid brass "Emergency" 5C Collet can be machined for the second operation. Didn't get the chance to try that. I had the luxury of doing parts like this on a Swiss 99% of the time and only did this on a Regular Lathe once in 321SS. What a PITA Mean part, very mean. LOL, lots of polishing too.BTW: There is a new BCC user site here http://cadcamtrainer.com/forums/index.php And Sorins Training Videos for BCC here http://www.cadcamtrainer.com/index.html
#11
| I am prompted to ask what are these for? They look like something that is pasrt of an articulating holder; each sphere being held in a clamp. I have a camera mount that has two balls on the end of a stem almost identical to these. If this is the case you don't need a full sphere, the end of the sphere opposite the stem can be flat without altering the function. This change would mean you could part them off finished from bar stock. |
#12
Runs would be around 150 pcs. If it gets into the thousands, the job will be contracted out.
Just kidding. These are friction ball joints for a photo light. At this time we have allot of options available to us including just buying the ball from a ball mfg. and boring holes to press fit stems. That is probably the fastest cheapest way in the long run. Also the ball is not clamped with a knob but by a bushing in back preloaded with belville washers. ----------- Edited I am in the middle of converting a manual lathe to CNC. I ditched the compound slide and want to create a custom tool holder. If I can do that, and if I can cut in both directions, then this is what I had in mind, what do you think? I would cut one side of the ball with L then the other side in other direction with R flipped over on other side of piece Last edited by jorgepease; 09-09-2006 at 10:23 AM. Reason: added info |
