#13
You ask; "Couldn't you just feed the bar a bit further when cutting the other side of the ball closest to the chuck?" You cannot machine the ball all the way down to the centerline because it breaks off on your roughing cut. You need a small stem still holding the ball until it is finished and then you part off at this stem. I have modified my sketch to show the sequence for doing these complete from bar stock with a small flat at each end. There will always be a little tip left after parting so you will nee to do a final operation to take this off. The small flat is totally irrelevant to your function; believe me, we make an almost identical but larger part used for a different application. One version of our balljoint can hold a maximum torque of 40 lbft. Incidentally forget about buying and boring balls the most economical way will be from barstock using a barfeeder; per part time on the machine will be well below 1 minute machining brass, aluminum or leaded steel and the hand removal of the tip will be just a few seconds. |
#14
#15
Yes, it is very small - but there are 42 of them. It's modular with very high tech. electronics. I think with both tools on the same side, I might have problems with my little bench lathe, if they cut at same time. I think I can work out the code though, I am playing with this software allot now. Thanks for you great ideas!! |
