In the next day or so hopefully I'll be taking possession of a "new to me" mill. It has one small glitch that I'm aware of immediately (and probably more that I'll learn about after I try to use it). Someone went a little too low on the table and milled it a bit. Is this something that: a) I should be worried about? b) that can be repaired? I have a TIG and I was thinking if I just heated the table up with a torch a bit and then filled it in and sanded it smooth, I could probably fix it. But I don't know if the heat will hurt anything else but I would worry about just TIGging a big chunk of metal like that without pre-heating it a little. Any suggestions...I searched and didn't really find anything. |
| Put aTooling Plate on it the full size of the table. http://cgi.ebay.com/New-Matrix-Tooli...QQcmdZViewItem |
Anyway...the table is something like 45" wide so I still have plenty of smooth surface to work with. I just never see tables with scarred surfaces so I wasn't sure if it's something to be worried about. I'm over it. Thanks everyone. |
| Chris64, You could chemically clean the surface(s) you want to restore; overfill the surface(s) with Devcon plastic steel/iron or some other; let it cure properly; fly cut the surface to match the table surface. Cosmetically, an orbital sander and steel wool look a lot like a smooth used surface.
__________________ DZASTR |
