  #13
Old 08-15-2006, 11:39 PM
Moderator
JerryFlyGuy is on a distinguished road
And 150# steam pipe? seriously though... its 1 1/2" "black" pipe... I'm pretty much faced w/ put it together and then mark down the sizes for the next time..
Jerry..
JerryFlyGuy
The more I know... the more I realize I don't
  #14   Ban this user!
Old 08-16-2006, 08:25 AM
Jay_At_CJT is on a distinguished road
O.K., so somebody please explain what I'm missing here. So even though you're machining on a cnc lathe, doesn't it still have a turret in which you could mount a reamer? And wouldn't that be easier and quicker than boring the taper? Or is something like this a case of not enough parts to justify new tools?
  #15   Ban this user!
Old 08-16-2006, 09:20 AM
pimpbike's Avatar
pimpbike is on a distinguished road
Reaming the taper would be slower and more costly if you don't already own that taper reamer. Boring it would definitely be the best way.
Jerry, are you trying to couple 2 pipes using a collar? If you're machining all the parts yourself I would follow the machinist handbook. If you’re buying parts off the shelf and trying to figure out lengths I wouldn't go by the book because most of the pipe thread elbows, couplers etc are coming from China these days and the quality control is not there. Do a dry fit in that case and measure the depths if it needs to be ultra precise.
  #16   Ban this user!
Old 08-16-2006, 09:31 AM
ddwinn is on a distinguished road
Yeah, you could use a reamer if you had one. It will take about 2 seconds to bore. The NPT is a 1" 11-1/2. Thanks.
Old 08-16-2006, 10:23 AM
Moderator
Pimp, no I'm actually just using 'off-the-shelf' stuff to design a water pipe,fuel and steam piping. I've not designed piping to this level before so.. its a learning experiance in itself. I'm trying to map out as much of the process as I can to simplify ordering and assembly. I can do just the mechanical layout and let a pipe fitter do the rest, but I've been asked to do what the pipe fitter would do, in figuring out all the fittings and the needed pipe lengths before we start. We're making several [like 18] of these system's so we want it to be kinda 'cut and paste' for each one.. I might just end up doing a prototype for the first one.. and then using those numbers to order for the following 17 units.
Jerry
JerryFlyGuy
  #18   Ban this user!
Old 08-16-2006, 10:31 AM
Originally Posted by JerryFlyGuy
... but I've been asked to do what the pipe fitter would do, in figuring out all the fittings and the needed pipe lengths before we start. We're making several [like 18] of these system's so we want it to be kinda 'cut and paste' for each one.. I might just end up doing a prototype for the first one.. and then using those numbers to order for the following 17 units. Jerry
Jerry this is high risk. As you know pipe threads are tapered and you cannot predict exactly where they will pull up tight. Also if one pipe fitter is a little guy and another is a gorilla you can get a turn or two difference on each joint. I suggest you identify locations in the piping network where you can simply spec out a nominal lengths and have these cut and threaded on site to accommodate accumulative errors. Probably at the locations where you put unions.
Old 08-16-2006, 10:38 AM
Moderator
Thanks Geof.. thats pretty much what I've done already.. but was hoping the 'black art' ..wasn't.. .. anyway I'll get most of it close and then we'll have to just 'as build' about 5 pc's each time to make it work.. I haven't found a way around it at this point.. it has to fit several lazer cut holes in the shack's and like you say.. it's probably not going to go together exactly the same each time anyway.. oh well.. it was worth asking.. this way I have a leg to stand on when I go back to my higher ups and say.. 'not gonna happen'
Thanks guy's.. I'll bow out of your thread.. and let ya'll continue..
Sorry for the temporary hijack..
Jerry
JerryFlyGuy
