  #13   Ban this user!
Old 08-16-2006, 01:33 AM
Joseph Souza is on a distinguished road
Forget the Carbide use OSG SUS Gold Drills you'll see better results, no center drilling , longer tool life and less cost?
Let me know what you think.
joe_souza@sbcglobal.net
  #14   Ban this user!
Old 08-16-2006, 02:02 PM
bma137 is on a distinguished road
Originally Posted by dertsap
i highly doubt the speed is too high ,ive been using a similar drill in 4140 forgings 4700rpm @ 42"/min 1.75 dp
did you dial up the drill to make sure there is 0. runout
Dertsap, this sounds crazy, what diameter is it? and what collets are you using?
also is it a VMC or HMC?
Old 08-16-2006, 07:13 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
13/16 kenametal ( same stuff), on a vmc , er collets , we don t plan to drill a million holes at that but it works for what we need
spot drilling and center drilling has been pointed out a couple of times ,
the ONLY time to spot is on a really bad surface , not recommended or required for carbides otherwise
not telling you to neccessarily go by my example , only what the tools are capable of
