Old 08-11-2006, 11:37 AM
Kool Parts's Avatar
Kool Parts is on a distinguished road
Pastics..help machining
Lets talk plastics. The outfit I want to order from has
High, and low density polyethyene,
Natural Nylon 6/6,
Cast Nylon 6 with Molybdenum Disulphide,
All of these are in square bar form. My only need is a nice finish. The cast is black, and that would be prefered, but not a deal breaker.
Gary
Old 08-11-2006, 11:47 AM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
All of these are very, very easy to machine. HDPE is the cheapest, the MD Nylon (Nylatron GS) is more expensive. HDPE machines with a great finish (so does the MD Nylon) but is just a hair more difficult to 'deburr' than the Nylon. Nylons will absorb moisture and so will the HDPE - dimensional stability and UV protection are some of the properties to consider. The MD Nylon is the most stable on the list but is far more expensive.
I have attached a cost comparison between numerous plastics and other materials - this was done a few months ago when I was searching for an inexpensive prototyping/proofing material. THis file may have more info than you need, but here it is.
You may want to look at the Acetals. Very pricey, though.
Scott
Consistency is a good thing....unless you're consistently an idiot.
Old 08-11-2006, 12:03 PM
Kool Parts's Avatar
Scott,
Thanks, I will keep that for future ref. One of my guys remided me that MSC carries Nylon... Duuuu.
And its in black. They offer a Nylon6/6 and a 6/6 that is MDS filled. They claim better machining a increased lubricity. But its is cheaper?? Sounds like the way to go. Normaly better is not cheaper
Gary
Old 08-11-2006, 01:44 PM
*Registered*
lakeside is on a distinguished road
also for materail Mcmaster Carr has materail property and user info on web site and carries all above
Old 08-11-2006, 02:02 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
You can check out www.use-enco.com as well.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 08-11-2006, 03:24 PM
Kool Parts's Avatar
Thanks for the replies,
I am going with the nylon. As far as properties go..I just needed a step above wet newspaper..Just really need a nice finish.
Gary
