Old 08-04-2006, 08:29 PM
larry53 is on a distinguished road
Knurling
I have knurled many times on a manual lathe,but each time I used a diagonal or straight knurl. Has anyone ever used a diamond knurl,male or female ? If so is more or less pressure required then diagonal knurling? Do you use two of the same if you are knurling male diamonds and two of the same if you are knurling female diamond knurls? Larry
