Hi all. I am new this and have a cnc mill with Centroid M400 control. I can't program yet without the conversational Centroid program. I have a job making 100 parts that have a spherical hole on the inside and a spherical outside. I have been looking on the web for quite a while but so far been unable to find a way to cut these profiles. The machine can do thread milling so there must be a way to do the spherical hole. Can anyone help with this one. Thanks. Bob |
| I can open dwg e-mail with explanation of what your looking for,sent to mikelakeside@comcast.net |
| You could draw the arc and markout points along the arc at your stepover spacing. Then write code using the XYZ points adding G02/G03 so the tool will do one revolution at each Z level. Also add a line G01 to move to the next Z point. Something like this: G90 G17 ;Absolute, XY Plane G01 X21.6591 Y0 Z0 G03 X21.6591 Y0 I-21.6591 J0 G01 X21.4678 Y0 Z-0.4619 G03 X21.4678 Y0 I-21.4678 J0 G01 X21.2764 Y0 Z-0.9239 G03 X21.2764 Y0 I-21.2764 J0 If you supply the details: Diameters, Tool Dia. (Ball nose?), Step-Over. I will look at generating for you. (I have a Macro to generate code for tapered holes but with some modifications I think I can alter to do a sphere.) |
| Powermax.....Add the drawing as attachment. Can send to me. aamcgreg@es.co.nz |
#11
| Bob...I'm the one that should be sorry. I hadn't read your 1st post properly. To make 100 this should be getting done on a lathe. The mill is good for the bolt holes, but the rest will take ages compared to a lathe. To generate the code I need to know the tool diameter and if a ball nose? (The code will be actual path, not G41/G42.) |
